coq-club - Re: [Coq-Club] coq_makefile -I X -as Y
  • To: Frédéric Blanqui <frederic.blanqui AT inria.fr>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] coq_makefile -I X -as Y
  • Date: Tue, 14 May 2013 07:25:46 -0400
Hi, Frederic --
That syntax doesn't seem to work either
coq_makefile -I foo bar a.v
produces:
COQLIBS?=-I .\
  -I foo
If you look in the source code, there are only rules for parsing '-R A B' and '-I A', no other rules.
I wrote a patch yesterday for this, but mostly for the parser, I don't know what semantic things need to be chnaged inside coq_makefile.
On Mon, May 13, 2013 at 8:16 PM, Frédéric Blanqui <frederic.blanqui AT inria.fr> wrote:
Hi.
You should use the following syntax instead:
coq_makefile -R my_lib_dir Lib
Le 14/05/2013 02:27, Gregory Malecha a écrit :
Hello --
Is there a way to get coq_makefile to notice the -as option that is allowed after -I by
coqc? For example:
coqc -I my_library -as Lib ...
works, but when I pass '-as Lib' to coq_makefile, it seems to completely ignore it:
coq_makefile -I my_library -as Lib ....
will generate a Makefile that runs commands like
coqc -I my_library ....
If it isn't implemented yet, I might be able to write a patch if someone can point me to the right place.
Thank you.
gregory malecha
http://www.people.fas.harvard.edu/~gmalecha/ <http://www.people.fas.harvard.edu/%7Egmalecha/>
gregory malecha
