coq-club - [Coq-Club] Automatic definition unfoldment in Ltac
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Automatic definition unfoldment in Ltac
  • Date: Wed, 15 May 2013 16:31:52 +0900
Hello all,
I have a question on automatic definition unfoldment in Ltac.
I will represent this issue with minimal example.
First, my goal was to give Ltac for every module which has "eq" interface, as belows:
    Module Type HasEqSpec (Export E:EqualityType').
      Parameter eq_refl: Reflexive eq.
      Parameter eq_sym: Symmetric eq.
      Parameter eq_trans: Transitive eq.
    End HasEqSpec.
    Module EqSolver (E:EqualityType') (F:HasEqSpec E).
      Ltac solve_eq :=
        repeat
          (match goal with
                 | [ H: E.eq ?a ?b |- E.eq ?b ?a] => apply F.eq_sym
                 ... (omitted for brevity) ...
           end).
    End EqSolver.
And I implemented "Module Interval_raw" which follows the interface EqualityType' and HasEqSpec.
Finally, I created "Module Interval" as belows:
    Module Interval := Interval_raw <+ EqSolver.
However, when I tried to prove the lemma below with "solve_eq", the proof simply failed.
    Lemma eq_sym_real : forall x y:Interval.t, Interval.eq x y -> Interval.eq y x.
    Proof.
      intros.
      Interval.solve_eq. (* Nothing changed *)
    Admitted.
I tried to find the reason why nothing is changed after applying my tactic,
and I found that defition "E.eq" was unfolded; I checked with "Print Ltac Interval.solve_eq".
So the question is:Is there any way not to unfold the definition "E.eq" in Ltac?
I am also wondering that why definitions in Ltac are unfolded.
best regards,
Joonwon Choi.
  • [Coq-Club] Automatic definition unfoldment in Ltac, Joonwon Choi, 05/15/2013
