coq-club - Re: [Coq-Club]
Re: [Coq-Club]
  • To: Math Prover <mathprover AT yahoo.com>
  • Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club]
  • Date: Sat, 18 May 2013 13:43:44 +0200
Another round of guesswork :), an explanation of what happens behind
the scene would be very much appreciated!
Following the source for nat, I found a way to register the decision proc:
Inductive aa := asdf : aa.
Theorem eq_aa_dec : forall n m : aa, {n = m} + {n <> m}. decide equality. Qed.
(*this registers the decision proc*)
Instance aa_eq_eqdec : EqDec aa eq := eq_aa_dec.
Definition fun3 (lst: list (aa * aa)) (k: aa) := assocList2_r lst k.
On Sat, May 18, 2013 at 12:52 PM, Math Prover
wrote:
> [Changed to a human sounding name.]
> I have another stupid question. Please see attached fail (pasted below).
> This is what baffles me:
> Why does this work with EquivDec, but not { x = y } + { x <> y} ?
> What makes absolutely no sense to me is:
> * There is only one way to define structural equality.
> * There are many possible equivalence definitions
> * Example 1: structural equality
> * Example 2: return true on everything
> Now, in the following code, I have two pieces of code that are
> syntactically almost the same -- yet, in the "structural equality" case,
> Coq can't infer Keq, yet ... in the "more general" Equivalence case, Coq
> can infer Keq.
> What incorrect assumption am I making? :-)
> ~/z/cur$ cat fail.v
> Require Import Bool Arith ZArith Arith.Peano_dec List Coq.Classes.EquivDec.
> Local Open Scope Z_scope.
> Section assocList1.
> Variable K: Type.
> Variable V: Type.
> Variable Keq: forall k1 k2: K, {k1 = k2} + {k1 <> k2}.
> Variable Veq: forall v1 v2: V, {v1 = v2} + {v1 <> v2}.
> Function assocList1_r (lst: list (K * V)) (k: K) : option V :=
> match lst with
> | nil => None
> | (k',v') :: xs => if Keq k k' then Some v' else assocList1_r xs k
> end.
> End assocList1.
> Section assocList2.
> Variable K: Type.
> Variable V: Type.
> Variable Keq: EqDec K eq.
> Function assocList2_r (lst: list (K * V)) (k: K) : option V :=
> match lst with
> | nil => None
> | (k',v') :: xs => if Keq k k' then Some v' else assocList2_r xs k
> end.
> End assocList2.
> Implicit Arguments assocList1_r [K V Keq].
> Implicit Arguments assocList2_r [K V Keq].
> (* up to this line all works *)
> (* the next line also works *)
> Definition fun2 (lst: list (nat * nat)) (k: nat) := assocList2_r lst k.
> (* why did the previous line work ??? *)
> (* the next line fails with error:
> Error: Cannot infer the implicit parameter Keq of assocList1_r. *)
> Definition fun1 (lst: list (nat * nat)) (k: nat) := assocList1_r lst k.
> ________________________________
> From: Feró
> <ferenc.tamasi AT gmail.com>
> To: Math Prover
> Cc:
> Sent: Saturday, May 18, 2013 2:45 AM
> Speculations follow, I hope someone will correct me:
> I guess, Check does not do "instantiation" only type checking, and for
> that there's enough information.
> If you do `Definition x := (assocList_r lst1 1).' instead of Check, it
> will also fail. That is, Coq will not try to guess which decision
> procedure you want to use as Keq.
> On Sat, May 18, 2013 at 3:36 AM, Math Prover
> wrote:
>> I'm using Coq 8.4 (downloaded from the main Coq website).
>> In the following block of code (also attached), I get an "Error: Cannot
>> infer the implicit parameter Keq of assocList_r." error.
>> I believe what I have is a minimal example.
>> What confuses me is that:
>> * when I use "Check" on the same types, it works
>> * when I define it as part of a Function, I get an "Cannot infer the
>> implicit parameter" error
>> Can someone please help me with:
>> 1) Letting me know if there's anyway I can reformat my question to make
>> it
>> easier to answer. (Or any additional information I should provide.)
>> 2) Tell me what I'm doing wrong / misunderstanding?
>> ===== Code ======
>> Require Import List Coq.Classes.EquivDec.
>> Section assocList.
>> Variable K: Type.
>> Variable V: Type.
>> Function assocList_r (lst: list (K * V)) (k: K) : option V :=
>> match lst with
>> | nil => None
>> | (k',v') :: xs =>
>> if Keq k k' then Some v' else assocList_r xs k
>> end.
>> End assocList.
>> Implicit Arguments assocList_r [K V Keq].
>> Definition lst1 := (1,2)::nil.
>> Check (assocList_r lst1 1).
>> (* Up until this line, all works *)
>> (* The following line gives me the error:
>> Error: Cannot infer the implicit parameter Keq of assocList_r. *)
>> Function f (lst: list (nat * nat)) (k: nat) :=
>> assocList_r lst k.
> Give me liberty or give me cash!
