coq-club - [Coq-Club] Removing proofs from a fixpoint
  • To: coq-club <coq-club AT inria.fr>
  • Subject: [Coq-Club] Removing proofs from a fixpoint
  • Date: Sat, 18 May 2013 18:10:57 -0400
Hi,
I have a fixpoint [f] which returns an element of [{ n : T | P n }].  Assuming that [f] does not use anything in [Prop] to construct the element of [T], I want to construct a fixpoint that returns a [T], which is provably equal to [f] on all elements, but which does not involve [P] anywhere.  I would like to do this without copy-paste.  Ideally, I'd like a tactic which manipulates the fixpoint and spits out an appropriate alternative definition.
For example, I'd like to be able to do something like
Fixpoint silly (n : nat) : { n' : nat | n = n' }
    := match n as n0 return {n' : nat | n0 = n'} with
         | 0 => exist _ 0 eq_refl
         | S n0 => let (n', H) := silly n0 in
                   match n' as n' return _ -> _ with
                     | 0 => fun _ => exist _ (S n0) eq_refl
                     | S n'' => fun H' =>  exist _ (S (S n'')) (f_equal S H')
                   end H
       end.
Definition silly_helper (n : nat) : nat.
  deconstruct_fix_point_tactic (silly n).
Defined.
Arguments silly_helper / .
Definition less_silly := Eval simpl in silly_helper.
Print less_silly. (* less_silly =
fix silly_helper (n : nat) : nat :=
  match n with
  | 0 => 0
  | S n0 =>
      match silly_helper n0 with
      | 0 => S n0
      | S n'' => S (S n'')
      end
  end
     : nat -> nat *)
Or, alternatively, (* less_silly =
  match n with
  | 0 => 0
  | S n0 =>
      match silly_helper return True -> _ with
      | 0 => S n0
      end I
  end
     : nat -> nat *)
The reason I want to do this is because my actual fixpoint has fairly large proof terms (and types of proof terms), and I would like to speed up simplifying through this fixpoint, so that Coq doesn't have to deal with the proof terms.
Thanks,
Jason
