coq-club - Re: [Coq-Club] Removing proofs from a fixpoint
  • To: Jason Gross <jasongross9 AT gmail.com>
  • Cc: AUGER Cédric <sedrikov AT gmail.com>, coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Removing proofs from a fixpoint
  • Date: Tue, 21 May 2013 14:27:35 +0200
Hi Jason,
In Mtac [1] you can do that, with dependent types and everything. Here
is an even sillier example illustrating the point:
Require Import mtac.
Fixpoint silly (n : nat) : { n' : nat | n = n' }
:= match n as n0 return {n' : nat | n0 = n'} with
| 0 => exist _ 0 eq_refl
| S n0 => let (n', H) := silly n0 in
exist _ (S n') (f_equal S H)
end.
Definition NotFixException : Exception.
exact exception.
Qed.
Definition deconstruct P (f : forall n : nat, {n' : nat | P n n'}) : M
(nat -> nat) :=
mmatch f with
| [(zp : P 0 0) (sp : forall n n', P n n' -> P (S n) (S n'))]
fix silly (n : nat) : {n' : nat | P n n'} :=
match n as n0 return {n' : nat | P n0 n'} with
| 0 => exist (fun n'=>P 0 n') 0 zp
| S n0 =>
exist _ (S n') (sp n0 n' H)
end
ret (fix silly (n : nat) :=
match n with
| 0 => 0
| S n0 => let n' := silly n0 in
S n'
end)
| _ => raise NotFixException
end.
Definition silly_helper := run (deconstruct _ silly).
Print silly_helper.
silly_helper =
fix silly (n : nat) : nat :=
match n with
| 0 => 0
| S n0 => let n' := silly n0 in S n'
end
: nat -> nat
Notice that the proofs for the base and the inductive case are
abstracted in the pattern.
Let me know if you have any questions.
Best,
Beta
[1] www.mpi-sws.org/~beta/mtac
On Sun, May 19, 2013 at 11:16 PM, Jason Gross
wrote:
> I think my message may not have made it to coq-club, because I pasted too
> much code into it. Sorry for any duplication. Here is my reply:
> I have not yet timed the performance, so my worries may not be valid. What
> I am worried about is as much, if not more, the size of the type of the
> proof terms as it is the size of the proof terms themselves. I already use
> the abstract command, but thanks.
> The problem with the Extraction command is that Ocaml is not dependently
> typed. I gave up on writing the computational parts of my fixpoint by hand
> because of problems with dependently-typed matches.
> -Jason
> On Sat, May 18, 2013 at 7:00 PM, AUGER Cédric
> wrote:
>> Le Sat, 18 May 2013 18:10:57 -0400,
>> Jason Gross
>> a écrit :
>> > Hi,
>> > I have a fixpoint [f] which returns an element of [{ n : T | P n }].
>> > Assuming that [f] does not use anything in [Prop] to construct the
>> > element of [T], I want to construct a fixpoint that returns a [T],
>> > which is provably equal to [f] on all elements, but which does not
>> > involve [P] anywhere. I would like to do this without copy-paste.
>> > Ideally, I'd like a tactic which manipulates the fixpoint and spits
>> > out an appropriate alternative definition.
>> > For example, I'd like to be able to do something like
>> > match n' as n' return _ -> _ with
>> > | 0 => fun _ => exist _ (S n0) eq_refl
>> > | S n'' => fun H' => exist _ (S (S n''))
>> > (f_equal S H')
>> > end H
>> > end.
>> > Definition silly_helper (n : nat) : nat.
>> > deconstruct_fix_point_tactic (silly n).
>> > Defined.
>> > Arguments silly_helper / .
>> > Definition less_silly := Eval simpl in silly_helper.
>> > Print less_silly. (* less_silly =
>> > fix silly_helper (n : nat) : nat :=
>> > match n with
>> > | 0 => 0
>> > | S n0 =>
>> > match silly_helper n0 with
>> > | 0 => S n0
>> > | S n'' => S (S n'')
>> > end
>> > end
>> > : nat -> nat *)
>> > Or, alternatively, (* less_silly =
>> > match n with
>> > | 0 => 0
>> > | S n0 =>
>> > match silly_helper return True -> _ with
>> > | 0 => S n0
>> > | S n'' => S (S n'')
>> > end I
>> > end
>> > : nat -> nat *)
>> > The reason I want to do this is because my actual fixpoint has fairly
>> > large proof terms (and types of proof terms), and I would like to
>> > speed up simplifying through this fixpoint, so that Coq doesn't have
>> > to deal with the proof terms.
>> > Thanks,
>> > Jason
>> I am not sure of what you want to do. When I mix proofs and fixpoints,
>> I use refine tactic to give the computational structure of the proofs
>> and put wildcards in the term where there should be proofs.
>> Then for each wildcard Coq asks me to fill in, I first assert all
>> required calls to the fixpoint "assert (Hx := <my fixpoint>
>> args).", then clear all non needed hypothesis (including the fixpoint),
>> and then do a one shot proof inside an abstract (well in fact, I first
>> do the proof, then add all the control using ";" for sequence of
>> scripts, "[, |, ]" for parallel scripts, and "(, )" to group scripts.
>> Once I have all the proof in one tactic, I use the "abstract" tactic
>> on it).
>> With abstract, you will have all proof related stuff in your fixpoint
>> set as opaque, so coq will have little to deal with the proof terms.
>> Note that you need to correctly clear your hypothesis (forgetting to
>> remove the fixpoint will lead to unguarded form, and you also have to
>> keep in mind that all hypothesis, even the uneeded one will be passed
>> to the abstracted proof).
>> Some other interesting stuff for you may be to use the Extraction
>> command. It extracts to Ocaml, but the syntax is a lot like Coq's one,
>> so you could copy-paste it.
