- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: [Coq-Club] match doesn't substitute?
- Date: Tue, 28 May 2013 15:33:12 +0200
Hi all,
apparently I don't know how matches work. I looked at the typing rules in Chapter 4 of the manual, but didn't really understand them. Let me give you an example to describe my lack of understanding.
I want to prove the following simple Goal:
Goal forall P : _ -> _ -> Prop, (P 0 0) -> (forall k n, (forall m, P k m) -> P (S k) n) -> (forall k n, P k n -> P k (S n)) -> forall k n, P k n.
intros P base stepl stepr.
Now my first attempt was to prove it as follows:
exact (fix l k := fix r n := match k as k, n as n return P k n with
| 0, 0 => base
| _, S n => stepr k n (r n)
| S k, _ => stepl k n (l k)
end).
However, r has type forall n, P k n - and not forall n, P 0 n; even though at that point in the match we know that k is 0.
My second attempt works, by deferring the "definition" of r until in the match:
exact (fix l k := match k as k return forall n, P k n with
| 0 => fix r n := match n as n return P 0 n with
| 0 => base
| S n => stepr 0 n (r n)
end
| S k => fun n => stepl k n (l k)
end).
Here, r has type forall n, P 0 n as k is 0. Why does Coq "forget" that k is 0 in my first attempt?
Kind regards, Jonas
- [Coq-Club] match doesn't substitute?, Jonas Oberhauser, 05/28/2013
- Re: [Coq-Club] match doesn't substitute?, Adam Chlipala, 05/28/2013
