coq-club - Re: [Coq-Club] match doesn't substitute?
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] match doesn't substitute?
  • Date: Tue, 28 May 2013 10:19:26 -0400
On 05/28/2013 09:33 AM, Jonas Oberhauser wrote:
exact (fix l k := fix r n := match k as k, n as n return P k n with
| 0, 0 => base
| _, S n => stepr k n (r n)
| S k, _ => stepl k n (l k)
end).
However, r has type forall n, P k n - and not forall n, P 0 n; even though at that point in the match we know that k is 0.
To understand what is going on here, I suggest Section 8.2, "The One Rule of Dependent Pattern Matching in Coq," in CPDT <http://adam.chlipala.net/cpdt/>. In particular, you seem to be assuming that [match] will refine the types of arbitrary variables (e.g., [r]) based on which patterns match, but it never does so.
You're mentioning [k] in some cases, and [k] itself is not refined with a known equality to a new value (e.g., [S] of something). In other words, in the second pattern rule, the mentions of [k] and [r] are both referring to "the old [k]," while the [match] typing rule wants the overall expression to have a type in terms of "the refined [k]."
Your approach to fixing the problem seems reasonable to me. CPDT introduces other design patterns for getting dependent [match]es to refine types in useful ways.
P.S.: It is always redundant to write [x as x] as you do above for your [match] discriminees.
