coq-club - [Coq-Club] Problems with Type Universes
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: [Coq-Club] Problems with Type Universes
  • Date: Mon, 17 Jun 2013 12:22:17 +0000
  • Accept-language: en-US
Dear Coq Club,
I'm having troubles in my current Coq development with Type hierarchies. When
defining a Fixpoint, the error message 'Universe Inconsistency' crops up. I
have created a small test file that illustrates my problems, but I am having
a very hard time understanding what actually is the problem. I have done the
hierarchies on paper and they seem to add up.
There are a few things that puzzle me in this example. First of all, I have a
definition of a partial function that is never used. If I remove this
definition, the universe inconsistencies disappear. Secondly, there are two
Fixpoints at the end, and it is always the second one that fails even if you
switch them around.
In the file, I have marked the lines that can safely be removed in order to
have the whole file compiled. I have also marked which Type uses are the
offenders where the Fixpoints start failing so that you don't have to look up
the numbers manually. I realise that the constraint system is being built
incrementally as new definitions are added to Coq, and here it seems to rear
its head by relating definitions that are completely independent (or at least
so I think) from each other.
Best regards
/Jesper
Attachment: Test.v
Description: Test.v
