- From: Robbert Krebbers <mailinglists AT robbertkrebbers.nl>
- To: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Order of subgoals due [rewrite] and [replace]
- Date: Mon, 17 Jun 2013 15:01:30 +0200
On 06/17/2013 10:34 AM, Arnaud Spiwack wrote:
There is indeed: rewrites at least are supposed to be chained, even whenI do not see why. In case of chained rewrites of the form
they have side conditions. It's easier to chain them if the main goal is
the first one
rewrite foo, bar, baz
that should just be an implementation problem, not a problem for the end user. In case of
rewrite foo; rewrite bar; rewrite baz
the consecutive rewrites are applied to all sub goals (including the subgoals of the side conditions).
And on a related note, I still haven't brought myself to write a tacticDoesn't ssreflect have syntax for that? How about borrowing that?
to reorder goals. Mostly because I haven't settled on the syntax.
Robbert
- [Coq-Club] Order of subgoals due [rewrite] and [replace], Robbert Krebbers, 06/15/2013
- Re: [Coq-Club] Order of subgoals due [rewrite] and [replace], Arnaud Spiwack, 06/17/2013
- Re: [Coq-Club] Order of subgoals due [rewrite] and [replace], Robbert Krebbers, 06/17/2013
- Re: [Coq-Club] Order of subgoals due [rewrite] and [replace], Enrico Tassi, 06/17/2013
