- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: [Coq-Club] Promoting and through a forall
- Date: Tue, 18 Jun 2013 01:26:58 -0700
Hi,
This question si uncannily similar to my previous question. If I'm misunderstanding the same concept (and this is a repeat question), please call me out on it. However, I suspect something else is going on here:
## Goal:
I want a tactic to transform hypothesis of the form:
H: forall a b c d e, P1 /\ P2
// P1 and P2 can depend on a, b, c, d, e
into a hypothesis of the form:
H1: forall a b c d e, P1
H2: forall a b c d e, P2
## First step, "promoting the and"
== BEGIN ==
Ltac promote_and_hlpr P :=
idtac "pah input ==>" P;
match P with
| (forall x:?T, ?P') =>
idtac "pah capture ==>" P'; promote_and_hlpr P'
| _ => idtac "no match"
end.
Ltac promote_and :=
match goal with
| H: (forall x:?T, ?P) |- _ =>
promote_and_hlpr (forall x:T, P)
end.
Ltac promote_and2 :=
match goal with
| H: context [?a /\ ?b] |- _ =>
idtac "matched"
end.
Lemma lem1:
(forall (x y: nat), (x = 1 \/ x <> 1) /\ (y = 0 \/ y <> 0))
-> False.
intros.
promote_and.
promote_and2.
== END ==
## Problems I run into / Questions
Q1: promote_and2 fails to match. Is this because the "/\" is embedded within quantified variables, and this context can not match?
Q2: promote_and_hlpr only matches the outer, but fails to match the inner. In particular, the idtac output I get is:
== Begin ==
pah input ==> (forall x y : nat, (x = 1 \/ x <> 1) /\ (y = 0 \/ y <> 0))
pah capture ==> (forall y : nat, (x = 1 \/ x <> 1) /\ (y = 0 \/ y <> 0))
pah input ==> (forall y : nat, (x = 1 \/ x <> 1) /\ (y = 0 \/ y <> 0))
no match
== End ==
Why is it failing to match on the second call?
Thanks!
- [Coq-Club] Promoting and through a forall, Math Prover, 06/18/2013
- [Coq-Club] Re: Promoting and through a forall, Math Prover, 06/18/2013
- Re: [Coq-Club] Re: Promoting and through a forall, Jason Gross, 06/18/2013
