coq-club - [Coq-Club] Re: Promoting and through a forall
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: [Coq-Club] Re: Promoting and through a forall
  • Date: Tue, 18 Jun 2013 08:55:35 -0700
Resolved -- http://adam.chlipala.net/cpdt/html/Reflection.html#lab98 indeed is what I want.
On Tue, Jun 18, 2013 at 6:57 AM, Math Prover <mathprover AT gmail.com> wrote:
As a followup on this, are the formal terms I'm dealing with called:
  "reification" (changing Prop into a Coq List format) and
  "binders" (the forall problem I'm running into)
Furthermore, is understanding pages 314-317 of http://adam.chlipala.net/cpdt/cpdt.pdf the key to my problem?
Thanks!
On Tue, Jun 18, 2013 at 2:50 AM, Math Prover <mathprover AT gmail.com> wrote:
I have been thinking more about this question. And I think the problem is as follows:
  * in the intermediate stages of the my computation, the "Props" I'm passing around are NOT semantcailly valid props.
  * thus, what I want is a way to allow me to manipulate the AST of the Prop -- where it's okay for the intermedaite values to be invalid -- as long as my final output is a valid Prop
In particular, I'd love to somehow get this "Prop" as a nested list of symbols -- do some manipulation -- then convert it back to a Prop. I think this is the primitive / common theme I'm missing.
On Tue, Jun 18, 2013 at 1:26 AM, Math Prover <mathprover AT gmail.com> wrote:
Hi,
  This question si uncannily similar to my previous question. If I'm misunderstanding the same concept (and this is a repeat question), please call me out on it. However, I suspect something else is going on here:
## Goal:
  I want a tactic to transform hypothesis of the form:
  H: forall a b c d e, P1 /\ P2
  // P1 and P2 can depend on a, b, c, d, e
  into a hypothesis of the form:
  H1: forall a b c d e, P1
  H2: forall a b c d e, P2
## First step, "promoting the and"
== BEGIN ==
Ltac promote_and_hlpr P :=
    idtac "pah input   ==>" P;
  match P with
  | (forall x:?T, ?P') =>
    idtac "pah capture ==>" P'; promote_and_hlpr P'
  | _ => idtac "no match"
end.
Ltac promote_and :=
  match goal with
  | H: (forall x:?T, ?P) |- _ =>
      promote_and_hlpr (forall x:T, P)
  end.
Ltac promote_and2 :=
  match goal with
  | H: context [?a /\ ?b] |- _ =>
      idtac "matched"
  end.
Lemma lem1:
  (forall (x y: nat), (x = 1 \/ x <> 1) /\ (y = 0 \/ y <> 0))
    -> False.
intros.
  promote_and.
  promote_and2.
== END ==
## Problems I run into / Questions
Q1: promote_and2 fails to match. Is this because the "/\" is embedded within quantified variables, and this context can not match?
Q2: promote_and_hlpr only matches the outer, but fails to match the inner. In particular, the idtac output I get is:
== Begin ==
pah input   ==> (forall x y : nat, (x = 1 \/ x <> 1) /\ (y = 0 \/ y <> 0))
pah capture ==> (forall y : nat, (x = 1 \/ x <> 1) /\ (y = 0 \/ y <> 0))
pah input   ==> (forall y : nat, (x = 1 \/ x <> 1) /\ (y = 0 \/ y <> 0))
no match
== End ==
  Why is it failing to match on the second call?
Thanks!
