- To: Gabriel Scherer <gabriel.scherer AT gmail.com>
- Cc: platform <platform AT lists.ocaml.org>, coq-club AT inria.fr
- Subject: Re: [ocaml-platform] [Coq-Club] Coq opam package
- Date: Tue, 18 Jun 2013 14:46:29 +0200
On 18/06/2013 13:48, Gabriel Scherer wrote:
I ran into OPAM Coq recompilation one time too many, and created a
(possibly alarmist) corresponding issue on the OPAM bugtracker:
https://github.com/OCamlPro/opam-repository/issues/805
PS: François, I hope you won't be offended by the frustrated tone of
the report. I very much appreciate the packaging work that you have
done (and contributions to the tool itself !). I just don't think that
OPAM is able to provide a good experience for the Coq package right
now, so it probably shouldn't be, in its present form, in the default
repository. I may also not be seeing the whole picture: if you or
others have clear use-cases for using the OPAM packages of, say,
Frama-C (as opposed to dumb binary releases for users and manual
compilation for developpers), it would be interesting to explain them
in the bugreport discussion.
Don't worry no offense taken. I didn't request a merge for the following commit (that extract coqide and its dependencies to another package and that would have saved your day) because it is more a hack than a real solution. I was looking for a better solution because I'm also frustrated ( today I have the pleasure to do opam upgrade
- recompile camlp5.6.07 [upstream changes]
- recompile coq.8.4pl1 [use camlp5]
Leaf project (in the dependency graph) like Frama-C are less a problem and since other project can depend on their libraries and binary (ex:Why2) its good to have them in opam. Moreover Frama-C takes only 2min to compile.
On Wed, Apr 17, 2013 at 11:43 AM, François
Bobot<francois.bobot AT cea.fr>
wrote:
https://github.com/bobot/opam-repository/commit/4c613c9c3bdd967785b7b251bf71c186203d28ca
I tried to reduce the compilation time of the coqide package by patching the
Makefile. The coq package compile in 15min on my computer. 'make coqide'
compile in 2 min, I reduced it to 30s by removing many of the
ocamldep/coqdep/.ml4 uselessly done.
branch coqide of
git AT github.com:bobot/opam-repository.git
If someone wants to make a try.
François
_______________________________________________
Platform mailing list
Platform AT lists.ocaml.org
http://lists.ocaml.org/listinfo/platform
- Re: [ocaml-platform] [Coq-Club] Coq opam package, Gabriel Scherer, 06/18/2013
- Re: [ocaml-platform] [Coq-Club] Coq opam package, François Bobot, 06/18/2013
- Re: [ocaml-platform] [Coq-Club] Coq opam package, Anil Madhavapeddy, 06/18/2013
