[Coq-Club] Searching for Declarations w/o seeing Definition/Proofs in Large Projects
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: [Coq-Club] Searching for Declarations w/o seeing Definition/Proofs in Large Projects
- Date: Fri, 21 Jun 2013 03:47:59 -0700
Hi,
This is a problem I'm running into while trying to manage ~2K loc
Coq project. I want to:
1. separate statement of lemma from proof of lemma
2. separate type declaration of Function from definition of Function
In particular, I would like to have a file structure that looks something
like:
=== BEGIN ===
Require Import ....
(* Just declarations *)
Function foo1 (args) : output-type.
Function foo2 (args) : output-type.
(* Just a statement *)
Lemma lem1:
something involving foo1 and foo2.
Function foo1 (args) : output-type :=
(* definition of foo1 *)
Function foo2 (args): output-type :=
(* definition of foo2 *)
Lemma lem1:
lem1 statement, proof of lem1.
=== END ===
Now, I realize there are two problems with this approach:
1) I'm repeating myself. I can accept this. Ideally, I'd like Coq to
check and make sure that the two definitions are the same.
2) This 'destroys' the interactive flow. When I add a new function
foo2 at the top of the file. The parts of code for foo1, foo2, and
lem1 becomes invalid. This is okay. I don't mind this when I add new
declarations.
I'm okay with both of the above. Is there anyway to have what I want
above? (mainly, I want a single place where all the Functions / Lemmas
so that when I'm searching for a particular function/lemma, I can only
look through the declarations without seeing the proofs).
Lastly, if the "right" way to do this to use some external tool which
looks at a *.v file and generates a separate file with the
declarations, I'm okay with that too.
Thanks!
- [Coq-Club] Searching for Declarations w/o seeing Definition/Proofs in Large Projects, Math Prover, 06/21/2013
- Re: [Coq-Club] Searching for Declarations w/o seeing Definition/Proofs in Large Projects, Yucheng Zhang, 06/21/2013
