Re: [Coq-Club] Searching for Declarations w/o seeing Definition/Proofs in Large Projects
- To: Math Prover <mathprover AT gmail.com>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Searching for Declarations w/o seeing Definition/Proofs in Large Projects
- Date: Fri, 21 Jun 2013 22:37:17 +0800
Note that in my last mail, the mentioned 'coqdoc' and 'coq2html' does not hide
definition of functions..
On Jun 21, 2013, at 6:47 PM, Math Prover
wrote:
> I'm okay with both of the above. Is there anyway to have what I want
> above? (mainly, I want a single place where all the Functions / Lemmas
> so that when I'm searching for a particular function/lemma, I can only
> look through the declarations without seeing the proofs).
Modules can be used for this purpose: use a Module Type for the declarations
and then a Module implements that module type. An example goes as follows:
Module Type A.
Parameter f : nat -> nat.
Axiom f_0 : forall x, f x = x + 1.
End A.
Module ImplA <: A.
Definition f x := x + 1.
Lemma f_0 : forall x, f x = x + 1.
Proof.
auto.
Qed.
End ImplA.
- [Coq-Club] Searching for Declarations w/o seeing Definition/Proofs in Large Projects, Math Prover, 06/21/2013
- Re: [Coq-Club] Searching for Declarations w/o seeing Definition/Proofs in Large Projects, Yucheng Zhang, 06/21/2013
