- From: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] "pretty" unfold of dependently-typed function
- Date: Thu, 27 Jun 2013 08:19:46 +0200
Le 27/06/2013 06:54, t x a écrit :
I'd prefer to use functions with dependent types rather than
returning an option A. However, I run into the problem where when I try
to "unfold" my function to prove things about it, the unfolded function
is very very ugly.
Definition z_nth {A: Type}
(i: Z)
(lst: list A)
(H: 0 <= i < (Z.of_nat (length lst))) : A.
Proof.
generalize dependent i.
induction lst as [| x xs].
(* nil case *)
crush.
(* x :: xs *)
intros i H. simpl in *.
pose proof (Z_dec' 0 i) as H_i_0.
destruct H_i_0 as [ [H_i_gt_0| H_i_lt_0] | H_i_eq_0].
(* i > 0; inductive case *)
apply (IHxs (i-1)). split. crush. crush.
rewrite (Zpos_P_of_succ_nat (length xs)) in H1. crush.
(* i < 0; can't happen *)
crush.
(* i = 0; return front *)
exact x. Defined.
The point is that the unfolded function is "very very ugly" because your proof is. You cannot expect Coq to produce a lambda-term with three branches if your proof has four!
Below is a variant that has exactly the structure you wanted, though it is a bit more verbose because the "fun H : ugly_type =>" binders have to be present, obviously.
Definition z_nth {A: Type} : forall (i: Z) (lst: list A)
(H: (0 <= i < Z.of_nat (length lst))%Z), A.
Proof.
fix 2.
intros i [|x xs] ; simpl ; intros H.
clear -H.
abstract omega.
case (Z_zerop i) ; intros H'.
exact x.
apply (z_nth (i - 1)%Z xs).
clear -H H'.
abstract (rewrite Zpos_P_of_succ_nat in H ; omega).
Defined.
The process of writing such functions is a bit convoluted, so you may first want to experiment with Program, as suggested by Daniel Schepler, as it offers a trade-off between ease-of-use and term ugliness.
Best regards,
Guillaume
- [Coq-Club] "pretty" unfold of dependently-typed function, t x, 06/27/2013
- Re: [Coq-Club] "pretty" unfold of dependently-typed function, Daniel Schepler, 06/27/2013
- Re: [Coq-Club] "pretty" unfold of dependently-typed function, t x, 06/27/2013
- Re: [Coq-Club] "pretty" unfold of dependently-typed function, Guillaume Melquiond, 06/27/2013
- Re: [Coq-Club] "pretty" unfold of dependently-typed function, Matthieu Sozeau, 06/27/2013
- Re: [Coq-Club] "pretty" unfold of dependently-typed function, Geoff Reedy, 06/27/2013
- Re: [Coq-Club] "pretty" unfold of dependently-typed function, Vincent Laporte, 06/27/2013
