- From: Vincent Laporte <vincent.laporte AT gmail.com>
- To: Geoff Reedy <geoff AT programmer-monk.net>
- Cc: t x <txrev319 AT gmail.com>, coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] "pretty" unfold of dependently-typed function
- Date: Thu, 27 Jun 2013 21:11:15 +0200
2013-06-27 18:03, Geoff Reedy:
> Definition z_nth {A: Type}: forall (i: Z) (lst: list A) (H: 0 <= i <
(Zlength lst)), A.
> refine (fix f (i: Z) (lst: list A) (H: 0 <= i < (Zlength lst)) : A :=
> match lst as x return (x = lst) -> A with
> | nil => (fun Heq => _)
> | x::xs => if Z_zerop i then (fun _ => x) else (fun
Heq => f (Zpred i) xs _)
> end (eq_refl lst)).
Hi,
Notice that there is no need for the extra `eq_refl` after the match.
Indeed if the hypothesis `H: 0 ≤ i < Zlength lst` is not introduced too
early, it can enjoy a different type in the two branches of the match.
Require Import ZArith List Psatz.
Local Open Scope Z_scope.
Definition z_nth {A: Type}: forall (i: Z) (lst: list A), 0 <= i <
Zlength lst -> A.
refine (fix f (i: Z) (lst: list A) : 0 <= i < Zlength lst -> A :=
match lst as x return 0 <= i < Zlength x -> A with
| nil => fun H => False_rect _ _
| x::xs => fun H =>
match Z_zerop i with
| left _ => x
| right K => f (i - 1) xs _
end
end).
Proof.
change (Zlength nil) with 0 in H. clear -H. abstract intuition.
clear -H K. abstract (rewrite Zlength_cons in H; lia).
Defined.
Happy τ day,
Vincent.
- Re: [Coq-Club] "pretty" unfold of dependently-typed function, (continued)
- Re: [Coq-Club] "pretty" unfold of dependently-typed function, Daniel Schepler, 06/27/2013
- Re: [Coq-Club] "pretty" unfold of dependently-typed function, t x, 06/27/2013
- Re: [Coq-Club] "pretty" unfold of dependently-typed function, Guillaume Melquiond, 06/27/2013
- Re: [Coq-Club] "pretty" unfold of dependently-typed function, Matthieu Sozeau, 06/27/2013
- Re: [Coq-Club] "pretty" unfold of dependently-typed function, Geoff Reedy, 06/27/2013
- Re: [Coq-Club] "pretty" unfold of dependently-typed function, Vincent Laporte, 06/27/2013
