- To: coq-club <coq-club AT inria.fr>
- Subject: [Coq-Club] testing if a variable has a concrete value
- Date: Tue, 9 Jul 2013 17:48:50 -0700
Hi,
With apologies for a vague-ish question (the word "concrete" must certainly have a technical definition): I want to see if a variable has a concrete value.
example non-concrete:
lst: list nat
example concrete:
lst: 1 :: 2 :: 3 :: nil
The motivation is as follows, on the following pattern:
context[ match nth _lst _i _d with ... end ]
if _lst is a concrete variable, then I want to run a tactic which considers the cases:
length _lst <= i \/
i = length_lst - 1 \/
i = ... \/
i = 2 \/
i = 1 \/
i = 0
Now, the issue is: I only want this to happen when _lst is a "concrete variable."
If all I know is that _lst is a "list nat", then I don't want to run this tactic.
Thus, my question: how can I test if a variable has a "concerete" value? (a negative of "it's not known to be possible" though highly unlikely, would be useful too)
Thanks!
- [Coq-Club] testing if a variable has a concrete value, t x, 07/10/2013
- Re: [Coq-Club] testing if a variable has a concrete value, Guillaume Melquiond, 07/10/2013
