- From: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] testing if a variable has a concrete value
- Date: Wed, 10 Jul 2013 07:04:01 +0200
Le 10/07/2013 02:48, t x a écrit :
With apologies for a vague-ish question (the word "concrete" must
certainly have a technical definition): I want to see if a variable has
a concrete value.
example non-concrete:
lst: list nat
example concrete:
lst: 1 :: 2 :: 3 :: nil
Ltac is_concrete_list l :=
match l with
| cons _ ?l => is_concrete_list l
| nil => true
| _ => false
end.
Then you just have to test the boolean and behave accordingly.
Note that matching is purely syntactic, so, depending on what you want to achieve, you might need Coq to perform a bit of computations beforehand, e.g.
let l := eval hnf in l in
match l with
| nil => true
| _ => false
end.
Best regards,
Guillaume
- [Coq-Club] testing if a variable has a concrete value, t x, 07/10/2013
- Re: [Coq-Club] testing if a variable has a concrete value, Guillaume Melquiond, 07/10/2013
