- To: coq-club <coq-club AT inria.fr>
- Subject: [Coq-Club] Re: Forcing substitutions
- Date: Mon, 15 Jul 2013 23:33:58 -0700
(as an update, here's a minimal example)
the issue that is not clear to me is:
*) why is it not substituting?
*) how do I force a substitution?
On Mon, Jul 15, 2013 at 11:05 PM, t x <txrev319 AT gmail.com> wrote:
I have a goal that looks something like this:==== BEGIN ====None =(fix z_nth_opt (lst : list K) (i0 : Z) {struct lst} : option K :=if i0 <? 0then Noneelsematch lst with| nil => None| x0 :: xs0 => if i0 =? 0 then Some x0 else z_nth_opt xs0 (i0 - 1)end) xs (i - 1)==== END ====I've tried "simpl/hnf" -- neither of which does anything.I've also tried "cbv/compute", which expands the code _inside_ the fix, but does not substitute "into" the fix.This is what I want:I want "xs" to be substitute in for lst. I want "(i-1)" to be substituted into as i0.Question: how do I tell a "fix" to substitute in the args?Thanks!
- [Coq-Club] Forcing substitutions, t x, 07/16/2013
- [Coq-Club] Re: Forcing substitutions, t x, 07/16/2013
- Re: [Coq-Club] Re: Forcing substitutions, Guillaume Melquiond, 07/16/2013
- Re: [Coq-Club] Re: Forcing substitutions, Duckki Oe, 07/18/2013
