- To: t x <txrev319 AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Re: Forcing substitutions
- Date: Wed, 17 Jul 2013 18:13:53 -0400
Hi, t x.
I wouldn't unfold the fix point definition like that. The function definition
is decreasing on the [lst] argument as {struct lst} states, but the head of
the function is matching on the "i0" argument. That's going to make your life
a bit harder. An alternative definition would be
Function z_nth_opt (lst: list K) (i: Z) : option K :=
match lst with
| nil => None
| x :: xs =>
if (i <? 0) then None
else
if (i =? 0)
then Some x
else z_nth_opt xs (i-1)
end.
This version matches on "lst" immediately, so "simpl" will be happier. And I
believe this version is observationally equal to your original definition. By
the way, I proved your theorem by induction on "xs". Also, here's a handy
script that helped my proof :)
Ltac lift :=
match goal with
| H: _ |- _ => apply -> Z.eqb_eq in H
| H: _ |- _ => apply <- Zlt_is_lt_bool in H
| H: _ |- _ => apply -> Z.ltb_ge in H
| _ => apply -> Zlt_is_lt_bool
| _ => apply <- Z.eqb_eq
end.
-- Duckki
On Tuesday, July 16, 2013 at 2:33 AM, t x wrote:
> (as an update, here's a minimal example)
> https://gist.github.com/anonymous/0b02f3ad30e154515b87
> the issue that is not clear to me is:
> *) why is it not substituting?
> *) how do I force a substitution?
> On Mon, Jul 15, 2013 at 11:05 PM, t x
> (mailto:txrev319 AT gmail.com)>
> wrote:
> > I have a goal that looks something like this:
> > ==== BEGIN ====
> > None =
> > (fix z_nth_opt (lst : list K) (i0 : Z) {struct lst} : option K :=
> > if i0 <? 0
> > then None
> > else
> > match lst with
> > | nil => None
> > | x0 :: xs0 => if i0 =? 0 then Some x0 else z_nth_opt xs0 (i0 - 1)
> > end) xs (i - 1)
> > ==== END ====
> > I've tried "simpl/hnf" -- neither of which does anything.
> > I've also tried "cbv/compute", which expands the code _inside_ the fix,
> > but does not substitute "into" the fix.
> > This is what I want:
> > I want "xs" to be substitute in for lst. I want "(i-1)" to be substituted
> > into as i0.
> > Question: how do I tell a "fix" to substitute in the args?
> > Thanks!
- [Coq-Club] Forcing substitutions, t x, 07/16/2013
- [Coq-Club] Re: Forcing substitutions, t x, 07/16/2013
- Re: [Coq-Club] Re: Forcing substitutions, Guillaume Melquiond, 07/16/2013
- Re: [Coq-Club] Re: Forcing substitutions, Duckki Oe, 07/18/2013
