- To: coq-club AT inria.fr
- Subject: [Coq-Club] Equivalent inductive definitions
- Date: Sun, 21 Jul 2013 23:56:20 +0200 (CEST)
Hi,
As a novice user of Coq, I have difficulties deciding what is the best
definition for an inductive type. For example, I have this definition of a
string set:
Inductive string_set: Set :=
| ss_empty: string_set
| ss_str: string->string_set
| ss_build: string_set->string_set->string_set.
which is appropriate for some purposes (a few fixpoints that I am writing).
However, for other purposes, I find it almost impossibile to advance with this
definition. In this case, the following definition suits better for my
objectives (another set of fixpoints):
| ss_build: string->string_set->string_set.
(the difference is in the type of ss_build constructor).
My question is: how can I be able to take advantage of both ways of defining
this inductive type, and thus be able to define all my fixpoints properly? Can
I combine them somehow? Or convert from one to the other? Or...?
Thanks in advance,
Marcus.
- [Coq-Club] Equivalent inductive definitions, Marcus Ramos, 07/21/2013
- Re: [Coq-Club] Equivalent inductive definitions, t x, 07/22/2013
- Re: [Coq-Club] Equivalent inductive definitions, Duckki Oe, 07/22/2013
