coq-club - Re: [Coq-Club] Equivalent inductive definitions
  • To: Marcus Ramos <mvmramos AT gmail.com>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Equivalent inductive definitions
  • Date: Mon, 22 Jul 2013 01:34:29 -0700
I recommend using something like:
(* note, following code not tested *)
Require Import List.
Definition string_set := list string.
Function ss_cons (s: string) (lst: list string) := a :: lst.
Function ss_union (s1: list string) (s2: list string) := s1 ++ s2.
On Sun, Jul 21, 2013 at 2:56 PM, Marcus Ramos <mvmramos AT gmail.com> wrote:
Hi,
As a novice user of Coq, I have difficulties deciding what is the best
definition for an inductive type. For example, I have this definition of a
string set:
Inductive string_set: Set :=
   | ss_empty: string_set
   | ss_str: string->string_set
   | ss_build: string_set->string_set->string_set.
which is appropriate for some purposes (a few fixpoints that I am writing).
However, for other purposes, I find it almost impossibile to advance with this
definition. In this case, the following definition suits better for my
objectives (another set of fixpoints):
   | ss_build: string->string_set->string_set.
(the difference is in the type of ss_build constructor).
My question is: how can I be able to take advantage of both ways of defining
this inductive type, and thus be able to define all my fixpoints properly? Can
I combine them somehow? Or convert from one to the other? Or...?
Thanks in advance,
Marcus.
