coq-club - Re: [Coq-Club] The implicit-argument-ness of type classes
  • To: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] The implicit-argument-ness of type classes
  • Date: Mon, 22 Jul 2013 09:31:07 +0200
On Mon, Jul 22, 2013 at 1:03 AM, Matthieu Sozeau
wrote:
>> Arguments elements _ _.
>> Print Implicit elements. (* Argument DM is implicit and maximally inserted
> That's unfortunate, maybe a bug? You could try the [Implict Arguments
> elements []]
> command instead.
On Mon, Jul 22, 2013 at 1:07 AM, Jason Gross
<jasongross9 AT gmail.com>
wrote:
> I think [Arguments elements : clear implicits.] might do what you want.
On Mon, Jul 22, 2013 at 1:10 AM, Robbert Krebbers
<mailinglists AT robbertkrebbers.nl>
wrote:
> I do not think it is a bug. You should use
Indeed! Thanks!
>> Furthermore, it seems to break other things, like the `elements`
>> coercion I asked for with `:>`:
>> Goal forall x y: E, (In _ elements x) -> x ≺ y. (* works fine *)
>> Goal forall x y: E, (In _ dm x) -> x ≺ y. (* error *)
>> If I use a Record instead of a Class, the coercion works as expected,
>> but then the implicit argument inference for ≺ doesn't work. Can I
>> somehow have my cake and eat it too?
> :> in a Class declaration does not declare a coercion (as documented in the
> reference manual) but an instance. You can certainly make elements a
> coercion
> afterwards using the [Coercion] command.
That doesn't seem to work either:
Definition ESet := Ensemble E.
Class DM := {
elements : ESet;
order : relation E
Coercion elements: DM >-> ESet.
Parameter dm: DM.
Goal forall x, (In _ (elements dm) x). (* works fine *)
Goal forall x, (In _ dm x). (* error *)
Bug?
To ask an unrelated question: Why can't I use `Ensemble E` directly in
the Coercion declaration? Apparently it requires a single identifier.
Thanks,
www.mhelvens.net
