- From: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
- To: Michiel Helvensteijn <mhelvens AT gmail.com>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] The implicit-argument-ness of type classes
- Date: Mon, 22 Jul 2013 10:01:32 +0200
On 22 juil. 2013, at 09:31, Michiel Helvensteijn
wrote:
>>> Furthermore, it seems to break other things, like the `elements`
>>> coercion I asked for with `:>`:
>>> Goal forall x y: E, (In _ elements x) -> x ≺ y. (* works fine *)
>>> Goal forall x y: E, (In _ dm x) -> x ≺ y. (* error *)
>>> If I use a Record instead of a Class, the coercion works as expected,
>>> but then the implicit argument inference for ≺ doesn't work. Can I
>>> somehow have my cake and eat it too?
>> :> in a Class declaration does not declare a coercion (as documented in the
>> reference manual) but an instance. You can certainly make elements a
>> coercion
>> afterwards using the [Coercion] command.
> That doesn't seem to work either:
> Definition ESet := Ensemble E.
> Class DM := {
> elements : ESet;
> order : relation E
> Arguments elements : clear implicits.
> Coercion elements: DM >-> ESet.
> Parameter dm: DM.
> Goal forall x, (In _ (elements dm) x). (* works fine *)
> Goal forall x, (In _ dm x). (* error *)
> Bug?
> To ask an unrelated question: Why can't I use `Ensemble E` directly in
> the Coercion declaration? Apparently it requires a single identifier.
Hi,
It's not unrelated, you can write Ensemble in the coercion declaration but
not applied, the coercion just needs the head constant. Then [In _ dm x]
checks.
Class DM := {
elements : Ensemble E;
order : relation E
Coercion elements: DM >-> Ensemble.
Parameter dm: DM.
-- Matthieu
- [Coq-Club] The implicit-argument-ness of type classes, Michiel Helvensteijn, 07/22/2013
- Re: [Coq-Club] The implicit-argument-ness of type classes, Matthieu Sozeau, 07/22/2013
- Re: [Coq-Club] The implicit-argument-ness of type classes, Jason Gross, 07/22/2013
- Re: [Coq-Club] The implicit-argument-ness of type classes, Robbert Krebbers, 07/22/2013
- Re: [Coq-Club] The implicit-argument-ness of type classes, Michiel Helvensteijn, 07/22/2013
