coq-club - [Coq-Club] How does Ltac unification work?
  • To: coq-club <coq-club AT inria.fr>
  • Subject: [Coq-Club] How does Ltac unification work?
  • Date: Wed, 31 Jul 2013 13:08:39 -0700
Hi,
I have a goal where the following succeed:
    lazymatch goal with |- ?f ?x0 ?x1 ?x2 ?x3 ?x4 ?x5 = ?g ?x0 ?x1 ?x2 ?x3 ?x4' ?x5
    => let check := constr:(eq_refl : f = g) in idtac
    end.
    => change f with g
    end.
    => let F := eval hnf in f in let G := eval hnf in g in constr_eq F G
    end.
    => pose Type as stupid;
      let F := eval cbv delta [stupid] in f in let G := eval cbv delta [stupid] in g in constr_eq F G
    end.
    => let T := type of f in let T' := type of g in constr_eq T T'
    end.
    => let F := constr:(fun _ : Set => f) in let G := constr:(fun _ : Set => g) in constr_eq F G
    end.
and the following fail:
    => constr_eq f g
    end.
    (* note the lack of [g] in the following match *)
    lazymatch goal with |- ?f ?x0 ?x1 ?x2 ?x3 ?x4 ?x5 = ?f ?x0 ?x1 ?x2 ?x3 ?x4' ?x5
    => idtac
    end.
note that [match goal with |- ?G => has_evar G end] fails, indicating that the problem is not evars.
Even more weirdly,
    lazymatch goal with |- ?f ?x0 ?x1 ?x2 ?x3 ?x4 ?x5 = ?f' ?x0 ?x1 ?x2 ?x3 ?x4' ?x5
    => let check := constr:(idpath : f = f') in idtac
    end.
    => progress change f with f'
    end.
fails, but if I switch the order of the lazymatches, then it goes through!
What's going on here?  I strongly suspect that this is a bug.  (Also, what's kind of reduction does [cbv deta [foo] in bar] do when [foo] doesn't appear in [bar]?)
-Jason
P.S. The code I'm working with is available at https://github.com/JasonGross/HoTT-categories/blob/3a47db011ea7ff6f7a3fcb538fd9bcefbd6e4b0f/theories/Grothendieck/ToCat.v#L194.  It only runs on top of HoTT/coq, sorry.
