- To: coq-club <coq-club AT inria.fr>
- Subject: [Coq-Club] Re: How does Ltac unification work?
- Date: Wed, 31 Jul 2013 14:45:29 -0700
I think it's a bug with universes. I've reported it at https://github.com/HoTT/coq/issues/52.
-Jason
Hi,I have a goal where the following succeed:lazymatch goal with |- ?f ?x0 ?x1 ?x2 ?x3 ?x4 ?x5 = ?g ?x0 ?x1 ?x2 ?x3 ?x4' ?x5=> let check := constr:(eq_refl : f = g) in idtacend.lazymatch goal with |- ?f ?x0 ?x1 ?x2 ?x3 ?x4 ?x5 = ?g ?x0 ?x1 ?x2 ?x3 ?x4' ?x5=> change f with gend.lazymatch goal with |- ?f ?x0 ?x1 ?x2 ?x3 ?x4 ?x5 = ?g ?x0 ?x1 ?x2 ?x3 ?x4' ?x5=> let F := eval hnf in f in let G := eval hnf in g in constr_eq F Gend.lazymatch goal with |- ?f ?x0 ?x1 ?x2 ?x3 ?x4 ?x5 = ?g ?x0 ?x1 ?x2 ?x3 ?x4' ?x5=> pose Type as stupid;let F := eval cbv delta [stupid] in f in let G := eval cbv delta [stupid] in g in constr_eq F Gend.lazymatch goal with |- ?f ?x0 ?x1 ?x2 ?x3 ?x4 ?x5 = ?g ?x0 ?x1 ?x2 ?x3 ?x4' ?x5=> let T := type of f in let T' := type of g in constr_eq T T'end.lazymatch goal with |- ?f ?x0 ?x1 ?x2 ?x3 ?x4 ?x5 = ?g ?x0 ?x1 ?x2 ?x3 ?x4' ?x5=> let F := constr:(fun _ : Set => f) in let G := constr:(fun _ : Set => g) in constr_eq F Gend.and the following fail:lazymatch goal with |- ?f ?x0 ?x1 ?x2 ?x3 ?x4 ?x5 = ?g ?x0 ?x1 ?x2 ?x3 ?x4' ?x5=> constr_eq f gend.(* note the lack of [g] in the following match *)lazymatch goal with |- ?f ?x0 ?x1 ?x2 ?x3 ?x4 ?x5 = ?f ?x0 ?x1 ?x2 ?x3 ?x4' ?x5=> idtacend.note that [match goal with |- ?G => has_evar G end] fails, indicating that the problem is not evars.Even more weirdly,lazymatch goal with |- ?f ?x0 ?x1 ?x2 ?x3 ?x4 ?x5 = ?f' ?x0 ?x1 ?x2 ?x3 ?x4' ?x5=> let check := constr:(idpath : f = f') in idtacend.lazymatch goal with |- ?f ?x0 ?x1 ?x2 ?x3 ?x4 ?x5 = ?f' ?x0 ?x1 ?x2 ?x3 ?x4' ?x5=> progress change f with f'end.fails, but if I switch the order of the lazymatches, then it goes through!What's going on here? I strongly suspect that this is a bug. (Also, what's kind of reduction does [cbv deta [foo] in bar] do when [foo] doesn't appear in [bar]?)-JasonP.S. The code I'm working with is available at https://github.com/JasonGross/HoTT-categories/blob/3a47db011ea7ff6f7a3fcb538fd9bcefbd6e4b0f/theories/Grothendieck/ToCat.v#L194. It only runs on top of HoTT/coq, sorry.
- [Coq-Club] How does Ltac unification work?, Jason Gross, 07/31/2013
- [Coq-Club] Re: How does Ltac unification work?, Jason Gross, 07/31/2013
