coq-club - Re: [Coq-Club] Applying a definition
  • To: "N. Raghavendra" <raghu AT hri.res.in>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Applying a definition
  • Date: Sat, 10 Aug 2013 12:49:22 -0500
You can use the tactic simpl to run coq compuations in Gallina. So, in this case, you can use simpl in H to run the andb and orb functions, and you end up getting
H: c = false
You can get the result you want from there.
-Andrew
On Sat, Aug 10, 2013 at 12:17 PM, N. Raghavendra <raghu AT hri.res.in> wrote:
I am trying to learn Coq from Benjamin Pierce's book on software
foundations.  While doing the exercise andb_eq_orb at
http://www.cis.upenn.edu/~bcpierce/sf/Basics.html#lab31
I did this:
Theorem andb_eq_orb :
  forall (b c : bool),
  (andb b c = orb b c) ->
  b = c.
Proof.
  intros b c H.
  destruct b.
This leads to the following goals:
2 subgoals
  c : bool
  H : andb true c = orb true c
   true = c
subgoal 2 is:
 false = c
Now, by definition `orb true c = true' , and `andb true c = c', so I
want to say
rewrite <- orb.
rewrite <- andb.
rewrite <- H.
reflexivity.
Qed.
This, however, produces an error message.  Is there a way to rewrite
terms in a proof using the definition of a function?
Thanks and best regards,
Raghu.
N. Raghavendra <raghu AT hri.res.in>, http://www.retrotexts.net/
Harish-Chandra Research Institute, http://www.hri.res.in/
