- To: Nuno Gaspar <nmpgaspar AT gmail.com>, Kristopher Micinski <krismicinski AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Proving equivalence of two different programs
- Date: Wed, 14 Aug 2013 19:58:58 +0530
Hello,
Following is a sample program in the context of concurrent
programming. There are two ways to implement atomic modification of
shared_data. First way is to use lock/mutex and the second one uses
atomic compare-and-swap. The outcome of these two variations is same
i.e. atomic modification of shared_data.
Now my question is much more constrained. So, can we prove equivalence
of programs like this?. Thanks!
void set(int a)
lock(&lk);
shared_data = a;
unlock(&lk);
void set(int a)
int data;
while(1)
int old = shared_data;
if(cmpxchg(&shared_data, old, a) == old)
return;
Manjeet Dahiya
http://manjeetdahiya.com
On Wed, Aug 14, 2013 at 7:44 PM, Nuno Gaspar
wrote:
> Hello.
> Well, generally speaking you'll first need to define what a program is and
> what do you mean by equivalence (I assume you want something more then
> simple syntactical equivalence)
> You may want to check Software Foundations, in particular the chapter on
> program equivalence: http://www.cis.upenn.edu/~bcpierce/sf/Equiv.html
> Hope it helps.
> 2013/8/14
> <manjeetdahiya AT gmail.com>
>> Hello,
>> I want to know if coq can be used to prove equivalence of two different
>> programs? Please give me some pointers if it is doable.
>> Thanks!
> Bart: Look at me, I'm a grad student, I'm 30 years old and I made $600
> dollars last year.
> Marge: Bart! Don't make fun of grad students, they just made a terrible life
> choice.
- [Coq-Club] Proving equivalence of two different programs, manjeetdahiya, 08/14/2013
- Re: [Coq-Club] Proving equivalence of two different programs, Kristopher Micinski, 08/14/2013
- Re: [Coq-Club] Proving equivalence of two different programs, Nuno Gaspar, 08/14/2013
- Re: [Coq-Club] Proving equivalence of two different programs, Manjeet Dahiya, 08/14/2013
- Re: [Coq-Club] Proving equivalence of two different programs, t x, 08/14/2013
- Message not available
- Re: [Coq-Club] Proving equivalence of two different programs, Joey Dodds, 08/14/2013
- Re: [Coq-Club] Proving equivalence of two different programs, Edward Z. Yang, 08/14/2013
