- To: Kristopher Micinski <krismicinski AT gmail.com>
- Cc: Manjeet Dahiya <manjeetdahiya AT gmail.com>, Nuno Gaspar <nmpgaspar AT gmail.com>, coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Proving equivalence of two different programs
- Date: Wed, 14 Aug 2013 14:55:04 +0000
This is do-able, provided you're willing to put in the time.
You can start out by defining a machine architecture (say formalizing MIPS).Then, you write a C -> Mips compiler (in Gallina).
After that, you can state the theorem in Coq, and try to formally prove it.
On Wed, Aug 14, 2013 at 2:41 PM, Kristopher Micinski <krismicinski AT gmail.com> wrote:
For these types of examples you may want to look at libraries like Bedrock, from what I know in my limited experience they handle sequential programs quite well. I'm not sure of the state for equality checking, however.KrisOn Wed, Aug 14, 2013 at 10:40 AM, Manjeet Dahiya <manjeetdahiya AT gmail.com> wrote:
Another example, where programs are sequential (no data sharing).
int f'(int x, int n)
int i, k = 0;
for (i=0; i!=n; ++i){
x += k;
k += 5;
if (i >= 5)
k += 15;
return x;
int f(int x, int n){
int i, k = 0;
x += k*5;
k += 1;
if (i >= 5)
k += 3;
return x;
On Wed, Aug 14, 2013 at 7:58 PM, Manjeet Dahiya <manjeetdahiya AT gmail.com> wrote:
> Hello,
> Following is a sample program in the context of concurrent
> programming. There are two ways to implement atomic modification of
> shared_data. First way is to use lock/mutex and the second one uses
> atomic compare-and-swap. The outcome of these two variations is same
> i.e. atomic modification of shared_data.
> Now my question is much more constrained. So, can we prove equivalence
> of programs like this?. Thanks!
> void set(int a)
> lock(&lk);
> shared_data = a;
> unlock(&lk);
> void set(int a)
> int data;
> while(1)
> int old = shared_data;
> if(cmpxchg(&shared_data, old, a) == old)
> return;
> Manjeet Dahiya
> http://manjeetdahiya.com
> On Wed, Aug 14, 2013 at 7:44 PM, Nuno Gaspar <nmpgaspar AT gmail.com> wrote:
>> Hello.
>> Well, generally speaking you'll first need to define what a program is and
>> what do you mean by equivalence (I assume you want something more then
>> simple syntactical equivalence)
>> You may want to check Software Foundations, in particular the chapter on
>> program equivalence: http://www.cis.upenn.edu/~bcpierce/sf/Equiv.html
>> Hope it helps.
>> 2013/8/14 <manjeetdahiya AT gmail.com>
>>> Hello,
>>> I want to know if coq can be used to prove equivalence of two different
>>> programs? Please give me some pointers if it is doable.
>>> Thanks!
>> Bart: Look at me, I'm a grad student, I'm 30 years old and I made $600
>> dollars last year.
>> Marge: Bart! Don't make fun of grad students, they just made a terrible life
>> choice.
- [Coq-Club] Proving equivalence of two different programs, manjeetdahiya, 08/14/2013
- Re: [Coq-Club] Proving equivalence of two different programs, Kristopher Micinski, 08/14/2013
- Re: [Coq-Club] Proving equivalence of two different programs, Nuno Gaspar, 08/14/2013
- Re: [Coq-Club] Proving equivalence of two different programs, Manjeet Dahiya, 08/14/2013
- Re: [Coq-Club] Proving equivalence of two different programs, t x, 08/14/2013
- Message not available
- Re: [Coq-Club] Proving equivalence of two different programs, Joey Dodds, 08/14/2013
- Re: [Coq-Club] Proving equivalence of two different programs, Edward Z. Yang, 08/14/2013
