coq-club - Re: [Coq-Club] Re: Dependent Type Minimal Example
  • To: Hugo Carvalho <hugoccomp AT gmail.com>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Re: Dependent Type Minimal Example
  • Date: Sun, 18 Aug 2013 22:39:41 +0000
Thank you!
This is amazing, worked on multiple (simple + complicated) examples I had with dependent types.
I have a really dumb question now:
Why do standard texts deal with all the guess work of:
  pattern _blah_;
  generalize dependent _blah_;
  apply dep_destruct;
  intros;
  generalize ...
  refine (UIP_refl ... );
where incorrect guesses gives back compiler complaints that abstracting Foo over Bar results in ill-typed form ...
The "refine" technique seems to be a silver bullet. Are there cases where "refine" fails, but manually generalizing / UIP_refl-ing terms makes things work?
On Sun, Aug 18, 2013 at 7:24 PM, Hugo Carvalho <hugoccomp AT gmail.com> wrote:
I'm not sure about how minimal this is, and the amount of inferences the refine tactic does might still be a bit too much magical, but here's my solution (assuming your change from "destruct" to "induction"):
simpl. rewrite IHexpr. refine (
match (expOpt Nat expr) with
 | NConst x => _
 | Inc x => _
end);reflexivity.
Also, here's a slightly different formulation, that i did in order to witness just how much was inferred by refine (and also to make a proof term without "ind" functions).
 Fixpoint lem' (expr: exp Nat) : expDenote _ (expOpt _ expr) = expDenote _ expr.
 refine (
 match expr with
 | NConst _ => _
 | Inc expr' => _
 end).
 reflexivity.
 simpl.
 refine (
 match (lem' expr') with
 | eq_refl => _
 end).
 refine (
 match (expOpt Nat expr') with
 | NConst x' => _
 | Inc x' => _
 end).
 reflexivity.
 reflexivity.
 Qed.
2013/8/18 t x <txrev319 AT gmail.com>
EDIT: last line is meant to be "induction expr; auto" not "destruct expr; auto"
On Sun, Aug 18, 2013 at 4:09 PM, t x <txrev319 AT gmail.com> wrote:
Hi,
  Can someone post a minimal solution to this (without using dep_destruct from cpdt tactics) ?
  https://gist.github.com/anonymous/6262395
  Proofs involving dependent types seems to high levels of "black magic" which makes it nearly impossible to debug. I'd like to see a minimal "manual" solution to see what's going on.
Thanks
