coq-club - Re: [Coq-Club] Dependent Type Minimal Example
  • From: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
  • To: t x <txrev319 AT gmail.com>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Dependent Type Minimal Example
  • Date: Tue, 20 Aug 2013 13:30:13 +0200
Hi t x,
This problem doesn't require equality reasoning, just inversion of Exp nat
which is readily defined from the dependent eliminator for exp.
Definition exp_nat_e (P : exp Nat -> Type)
(p0 : forall n, P (NConst n))
(pinc : forall e, P e -> P (Inc e)) : forall {e}, P e :=
exp_rect (fun t e =>
match t return exp t -> Type with
| Nat => P
| Bool => fun e => True
end e)
p0 pinc Nat.
Lemma expDInc e :
expDenote Nat (expOpt Nat (Inc e)) = S (expDenote Nat (expOpt Nat e)).
Proof.
simpl expOpt at 1. generalize (expOpt Nat e). clear e.
refine (@exp_nat_e _ _ _); simpl; auto.
Qed.
Lemma lem:
forall (expr: exp Nat),
expDenote _ expr = expDenote _ (expOpt _ expr).
Proof.
refine (@exp_nat_e _ _ _); [auto|].
simpl expDenote at 3. intros e ->. auto using expDInc.
Qed.
On 18 août 2013, at 18:09, t x
wrote:
> Hi,
> Can someone post a minimal solution to this (without using dep_destruct
> from cpdt tactics) ?
> https://gist.github.com/anonymous/6262395
> Proofs involving dependent types seems to high levels of "black magic"
> which makes it nearly impossible to debug. I'd like to see a minimal
> "manual" solution to see what's going on.
> Thanks
