- To: t x <txrev319 AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] rewrite as a function instead of a tactic
- Date: Thu, 22 Aug 2013 11:55:05 -0400
On Wed, Aug 21, 2013 at 08:43:58PM +0000, t x said
> I believe the process I want is called "beta expansion". Is there a way to
> fix type_rewrite so that line 14 behaves like line 32?
Beta expansion is what the pattern tactic does. I don't think there's a
a way to get what you want from Gallina without applying that tactic in
either the goal or the assumptions. Maybe you can write a tactic to
figure it out.
To show how the pattern tactic can be applied here, if you change
type_rewrite to
Definition type_rewrite {T : type} {Ht : T -> Type} {x y : T} (t : Ht x)
(H : x = y) := @eq_rect _ x (fun i => _) t y H.
then the proof scripts
intros a b H Heq.
pattern a in H.
pose proof (type_rewrite H Heq) as H2.
simpl in H2.
assumption.
and
intros a b H Heq.
pattern b at 1.
apply (type_rewrite H Heq).
go through. Not sure at all if this is useful to you.
-- Geoff
- [Coq-Club] rewrite as a function instead of a tactic, t x, 08/21/2013
- Re: [Coq-Club] rewrite as a function instead of a tactic, Geoff Reedy, 08/22/2013
- Re: [Coq-Club] rewrite as a function instead of a tactic, Jason Gross, 08/22/2013
