coq-club - Re: [Coq-Club] rewrite as a function instead of a tactic
  • To: t x <txrev319 AT gmail.com>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] rewrite as a function instead of a tactic
  • Date: Thu, 22 Aug 2013 12:50:29 -0400
[eq_rect] is the "rewrite function".  Unification is insufficiently powerful to auto-infer all the terms that you want inferred.  See also the notations "rew H in <term>", "rew <- H in <term>", "rew -> H in <term>" (also "rew H at <n> in <term>") which are apparently written in ml.
-Jason
On Wednesday, August 21, 2013, t x wrote:
I want the rewrite tactic as a rewrite function.
Line 32 correctly does the rewrite I want.
Line 14 fails the rewrite, likely beacuse in line 3, (fun X => _) ends up being (fun X => H) rather than (fun X => X + b = 10).
I believe the process I want is called "beta expansion". Is there a way to fix type_rewrite so that line 14 behaves like line 32?
Thanks!
