- From: Valentin Robert <valentin.robert.42 AT gmail.com>
- To: soham chakraborty <soham4you AT gmail.com>
- Cc: "N. Raghavendra" <raghu AT hri.res.in>, "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Re: Error: 1 * n = n.
- Date: Fri, 6 Sep 2013 11:09:09 +0100
You should download the files here and work through them:
http://www.cis.upenn.edu/~bcpierce/sf/
(Download in the bottom-right corner, then open Induction.v)
In particular, to work with Raghu's code, you will need at least the
following commands upfront:
Require String. Open Scope string_scope.
Ltac move_to_top x :=
match reverse goal with
| H : _ |- _ => try move x after H
end.
Tactic Notation "assert_eq" ident(x) constr(v) :=
let H := fresh in
assert (x = v) as H by reflexivity;
clear H.
Tactic Notation "Case_aux" ident(x) constr(name) :=
first [
set (x := name); move_to_top x
| assert_eq x name; move_to_top x
| fail 1 "because we are working on a different case" ].
Tactic Notation "Case" constr(name) := Case_aux Case name.
Tactic Notation "SCase" constr(name) := Case_aux SCase name.
Tactic Notation "SSCase" constr(name) := Case_aux SSCase name.
Tactic Notation "SSSCase" constr(name) := Case_aux SSSCase name.
Tactic Notation "SSSSCase" constr(name) := Case_aux SSSSCase name.
Tactic Notation "SSSSSCase" constr(name) := Case_aux SSSSSCase name.
Tactic Notation "SSSSSSCase" constr(name) := Case_aux SSSSSSCase name.
Tactic Notation "SSSSSSSCase" constr(name) := Case_aux SSSSSSSCase name.
- Valentin
On Fri, Sep 6, 2013 at 10:53 AM, soham chakraborty
wrote:
> Hi Raghu,
> Good to hear from you. I have also started with the same book but yet to
> study the case analysis part :)
> On the solution you sent Coq is getting stuck at
> Case "n = O". Error: No interpretation for string "n = O".
> Can you please check.
> Best Regards,
> soham
> On Fri, Sep 6, 2013 at 1:39 PM, N. Raghavendra
> wrote:
>> At 2013-09-05T23:47:34+05:30, soham chakraborty wrote:
>> > Using them I have found following ways to solve the theorem 1 * n =
>> > n. Please review and provide your feedback.
>> I've also just begun to learn Coq. This is an exercise in Pierce's
>> software foundations book:
>> http://www.cis.upenn.edu/~bcpierce/sf/Induction.html
>> At the level of that chapter, I'd solve this exercise as follows:
>> Theorem mult_1_l :
>> forall n : nat,
>> 1 * n = n.
>> Proof.
>> intros n.
>> induction n as [ | p IHp].
>> Case "n = O".
>> reflexivity.
>> Case "n = S p".
>> simpl.
>> simpl in IHp.
>> rewrite -> IHp.
>> reflexivity.
>> Qed.
>> Best regards,
>> Raghu.
>> N. Raghavendra
>> http://www.retrotexts.net/
>> Harish-Chandra Research Institute, http://www.hri.res.in/
- Re: [Coq-Club] Error: 1 * n = n., (continued)
- Re: [Coq-Club] Error: 1 * n = n., Colm Bhandal, 09/05/2013
- Re: [Coq-Club] Error: 1 * n = n., Valentin Robert, 09/05/2013
- Re: [Coq-Club] Error: 1 * n = n., Kristopher Micinski, 09/05/2013
- Message not available
- Re: [Coq-Club] Error: 1 * n = n., soham chakraborty, 09/05/2013
- Re: [Coq-Club] Error: 1 * n = n., t x, 09/05/2013
- Re: [Coq-Club] Error: 1 * n = n., soham chakraborty, 09/06/2013
- [Coq-Club] Re: Error: 1 * n = n., N. Raghavendra, 09/06/2013
- Re: [Coq-Club] Re: Error: 1 * n = n., soham chakraborty, 09/06/2013
- Re: [Coq-Club] Re: Error: 1 * n = n., Valentin Robert, 09/06/2013
