- To: "N. Raghavendra" <raghu AT hri.res.in>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Re: Error: 1 * n = n.
- Date: Fri, 6 Sep 2013 16:53:22 +0530
Hi Raghu,
Thanks for the explanation. Also your second solution(remove case) works without string.
Best Regards,Thanks for the explanation. Also your second solution(remove case) works without string.
On Fri, Sep 6, 2013 at 4:31 PM, N. Raghavendra <raghu AT hri.res.in> wrote:
At 2013-09-06T16:06:03+05:30, soham chakraborty wrote:"simpl in IHp" just simplifies IHp using the relevant definitions. The
> Thanks Valentin for the reference. Yes, these commands solve the
> problem and Raghu's solution works :)
> One query. In theorem n + 0 = n is not accepted (guess it is due to
> recursion as Nick suggested earlier). But "simpl in IHp." allows "p +
> 0 = p". Any particular reason?
induction hypothesis IHp is only a hypothesis available in the given
context, and not a theorem that can be used outside that context. In
particular, IHp is not the theorem
forall p : nat, p + O = p.
which needs a separate proof.
Print mult.
mult =
fix mult (n m : nat) {struct n} : nat :=
match n with
| 0 => 0
| S p => m + mult p m
end
: nat -> nat -> nat
Argument scopes are [nat_scope nat_scope]
IHp : 1 * p = p
By definition,
1 * p = mult 1 p = mult (S O) p = p + mult O p = p + O
So IHp is simplified as
IHp : p + O = O
Best regards,
Raghu.
N. Raghavendra <raghu AT hri.res.in>, http://www.retrotexts.net/
Harish-Chandra Research Institute, http://www.hri.res.in/
- Re: [Coq-Club] Error: 1 * n = n., (continued)
- Re: [Coq-Club] Error: 1 * n = n., Kristopher Micinski, 09/05/2013
- Message not available
- Re: [Coq-Club] Error: 1 * n = n., soham chakraborty, 09/05/2013
- Re: [Coq-Club] Error: 1 * n = n., t x, 09/05/2013
- Re: [Coq-Club] Error: 1 * n = n., soham chakraborty, 09/06/2013
- [Coq-Club] Re: Error: 1 * n = n., N. Raghavendra, 09/06/2013
- Re: [Coq-Club] Re: Error: 1 * n = n., soham chakraborty, 09/06/2013
- Re: [Coq-Club] Re: Error: 1 * n = n., Valentin Robert, 09/06/2013
