RE: [Coq-Club] Not sure if this is the right forum for beginners' questions, however .....
- To: Adam Chlipala <adamc AT csail.mit.edu>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: RE: [Coq-Club] Not sure if this is the right forum for beginners' questions, however .....
- Date: Sat, 7 Sep 2013 19:22:53 -0500
- Importance: Normal
I'm reading some chapters from Pierce's and started reading CPDT book. I'm currently interested in using Coq for program verification, so I came up with this question.
Thanks a lot.
Date: Sat, 7 Sep 2013 20:06:54 -0400
To: shigeonishi AT hotmail.com
CC: coq-club AT inria.fr
Subject: Re: [Coq-Club] Not sure if this is the right forum for beginners' questions, however .....
On 09/07/2013 08:01 PM, Shigeo Nishi wrote:
What source are you using to learn Coq? I expect most will introduce the tools you need here, probably as part of an introduction to inductive predicates.
Thanks a lot.
I'm a Coq beginner, but I think I have a question that has to do with this thread since I'm trying to prove that an inductive proposition with the wrong "evidence" is evaluated to False.
I'm stuck in this goal:
1 subgoals
H0 : isof2 (1 :: nil)
______________________________________(1/1)
False
- [Coq-Club] Not sure if this is the right forum for beginners' questions, however ....., Satrajit Roy, 09/07/2013
- Re: [Coq-Club] Not sure if this is the right forum for beginners' questions, however ....., t x, 09/07/2013
- Re: [Coq-Club] Not sure if this is the right forum for beginners' questions, however ....., Adam Chlipala, 09/07/2013
- Re: [Coq-Club] Not sure if this is the right forum for beginners' questions, however ....., Andrew Hirsch, 09/08/2013
- RE: [Coq-Club] Not sure if this is the right forum for beginners' questions, however ....., Shigeo Nishi, 09/08/2013
- Re: [Coq-Club] Not sure if this is the right forum for beginners' questions, however ....., Adam Chlipala, 09/08/2013
