Re: [Coq-Club] Not sure if this is the right forum for beginners' questions, however .....
- To: Satrajit Roy <satrajit.roy AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Not sure if this is the right forum for beginners' questions, however .....
- Date: Fri, 6 Sep 2013 23:39:09 +0000
I believe you need the law of excluded middle. In general, you can't prove
forall (P: Type), P \/ ~P.
Software Foundtaions / Pierce has a nice exercise showing that 5 statements (related to law of excluded middle) are equivalent.
On Fri, Sep 6, 2013 at 11:27 PM, Satrajit Roy <satrajit.roy AT gmail.com> wrote:
Why can't I prove:forall p:Type->Prop, ~(forall q:Type, (p q))->(exists q:Type, ~(p q))When I can easily prove:forall p:Type->Prop, exists q, ~p q->~forall q, p qor prove:forall p:Type->Prop, ~exists q, p q->forall q, ~p qor even prove:forall p:Type->Prop, forall q, p q->~exists q, ~p q
Satrajit
- [Coq-Club] Not sure if this is the right forum for beginners' questions, however ....., Satrajit Roy, 09/07/2013
- Re: [Coq-Club] Not sure if this is the right forum for beginners' questions, however ....., t x, 09/07/2013
- Re: [Coq-Club] Not sure if this is the right forum for beginners' questions, however ....., Adam Chlipala, 09/07/2013
- Re: [Coq-Club] Not sure if this is the right forum for beginners' questions, however ....., Andrew Hirsch, 09/08/2013
- RE: [Coq-Club] Not sure if this is the right forum for beginners' questions, however ....., Shigeo Nishi, 09/08/2013
- Re: [Coq-Club] Not sure if this is the right forum for beginners' questions, however ....., Adam Chlipala, 09/08/2013
