- To: Adam Chlipala <adamc AT csail.mit.edu>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Ltac question/challenge: working with open terms
- Date: Sun, 15 Sep 2013 15:01:59 -0700
> Have you read Section 15.5 of CPDT <http://adam.chlipala.net/cpdt/>? I
> haven't read all of the code you included, but the prose makes it sound
> like that section shows how to do what you're looking for.
Thanks, Adam. I missed that section when skimming CPDT looking for answers. It seems the trick here is using @? patterns in just the right way and uncurrying lambdas as you encounter them.
However, I'm still sort of stuck; trying to apply the technique to my setting gives me odd behavior I don't undersdand. In the final goal below, I expect the match to go into the "app" branch, but instead it goes into the "app no @?" branch. This seems like it might be a bug, because the branch succeeds on my example if I change the pattern to:
(plus (@?f x) (@?g x))
So maybe it doesn't want to match on partial applications for some reason? Any advice?
Ltac do_sk t k :=
idtac "do_sk" t;
lazymatch t with
| (fun (x:?T) => x) =>
idtac "x"; k 1
| (fun (x:?T) => (@?f x) (@?g x)) =>
idtac "app" f g; k 2
| (fun (x:?T) => ?f ?g) =>
idtac "app, no @?" f g; k 22
| (fun (x:?Tx) (y:?Ty) => (@?t' x y) ) =>
idtac "lambda" t'; k 3
| (fun (x:?T) => (@?t' x)) =>
idtac "other" t'; k 4
| _ => idtac "fallthrough" t
end.
Ltac sk t :=
do_sk t ltac:(fun m => idtac m).
Definition ten := 10.
Definition asdf (f:nat -> nat) := True.
Definition asdf2 (f:nat -> nat -> nat) := True.
Goal (asdf (fun w => w)).
match goal with [ |- asdf ?t ] => sk t end.
(* OK, as expected *)
Abort.
Goal (asdf2 (fun w w' => w)).
match goal with [ |- asdf2 ?t ] => sk t end.
Abort.
Goal (asdf (fun w => plus (plus ten w) ten)).
(* Hunh? I expect it to go into the "app" case
but it goes into "app no @?" instead.
Abort.
- [Coq-Club] Ltac question/challenge: working with open terms, robert, 09/15/2013
- Re: [Coq-Club] Ltac question/challenge: working with open terms, Adam Chlipala, 09/15/2013
- [Coq-Club] Ltac question/challenge: working with open terms, Jason Gross, 09/15/2013
- Re: [Coq-Club] Ltac question/challenge: working with open terms, robert, 09/16/2013
- Re: [Coq-Club] Ltac question/challenge: working with open terms, Adam Chlipala, 09/17/2013
- Re: [Coq-Club] Ltac question/challenge: working with open terms, Jason Gross, 09/18/2013
