- To: Adam Chlipala <adamc AT csail.mit.edu>
- Cc: robert <robdockins AT fastmail.fm>, "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Ltac question/challenge: working with open terms
- Date: Wed, 18 Sep 2013 00:15:01 -0400
The associated error message (from Set Ltac Debug) is "Only bound indices allowed in second order pattern matching." I'm not quite sure if this is expected behavior. However, there's definitely a bug here, in that "idtac f" mentions x(!), which is bound inside the function, but not at top level. (Set Ltac Debug gives me "Ltac variable f depends on pattern variable name x which is not bound in current context.")
I've submitted a bug for both of these at https://coq.inria.fr/bugs/show_bug.cgi?id=3130.
-Jason
On 09/15/2013 06:01 PM, robert wrote:However, I'm still sort of stuck; trying to apply the technique to my setting gives me odd behavior I don't undersdand. In the final goal below, I expect the match to go into the "app" branch, but instead it goes into the "app no @?" branch. This seems like it might be a bug, because the branch succeeds on my example if I change the pattern to:
(plus (@?f x) (@?g x))
So maybe it doesn't want to match on partial applications for some reason? Any advice?
That is definitely peculiar. It may be related to longstanding efforts (e.g., adding [appcontext]) to remove Ltac behavior that unreasonably reveals the representation of function application as n-ary in the kernel. I'd say it would be reasonable to file a bug report on this one!
Ltac do_sk t k :=(*...*)
| (fun (x:?T) => (@?f x) (@?g x)) =>
idtac "app" f g; k 2
| (fun (x:?T) => ?f ?g) =>
idtac "app, no @?" f g; k 22
- [Coq-Club] Ltac question/challenge: working with open terms, robert, 09/15/2013
- Re: [Coq-Club] Ltac question/challenge: working with open terms, Adam Chlipala, 09/15/2013
- [Coq-Club] Ltac question/challenge: working with open terms, Jason Gross, 09/15/2013
- Re: [Coq-Club] Ltac question/challenge: working with open terms, robert, 09/16/2013
- Re: [Coq-Club] Ltac question/challenge: working with open terms, Adam Chlipala, 09/17/2013
- Re: [Coq-Club] Ltac question/challenge: working with open terms, Jason Gross, 09/18/2013
