coq-club - [Coq-Club] Using Notation + Scope
  • To: coq-club <coq-club AT inria.fr>
  • Subject: [Coq-Club] Using Notation + Scope
  • Date: Sat, 21 Sep 2013 13:43:12 +0000
Hi,
  I'm trying to use Notation together with Scopes.
  The following is a minimal example which fails
Inductive foo := fA | fB.
Variable fAdd : foo -> foo -> foo.
Notation "A + B" := (fAdd A B) : foo_scope.
Check (fA + fB) % foo_scope.
>>> Error: Unknown scope delimiting key foo_scope.
How should I fix this? I'm rather baffled -- % foo_scope should mean that the "+" uses the Notation defined above, to be fAdd. Furthermore, the Notation line should have defined scope foo_scope and added a notation to it.
What am I doing wrong?
Thanks!
