- To: Vincent Laporte <vincent.laporte AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Using Notation + Scope
- Date: Sat, 21 Sep 2013 16:02:37 +0000
With apologies for my ignorance, I still can't get it to work. For example:
https://gist.github.com/anonymous/6651830
What am I doing wrong? I'm almost verbatim copying theories/String.v :
== Part of String.v
(** *** Definition of strings *)
(** Implementation of string as list of ascii characters *)
Inductive string : Set :=
| EmptyString : string
| String : ascii -> string -> string.
Delimit Scope string_scope with string.
Bind Scope string_scope with string.
Local Open Scope string_scope.
== End
On Sat, Sep 21, 2013 at 1:53 PM, Vincent Laporte <vincent.laporte AT gmail.com> wrote:
Le 2013-09-21 15:43, t x a écrit :
> I'm trying to use Notation together with Scopes.Hi,
> The following is a minimal example which fails
> Inductive foo := fA | fB.
> Variable fAdd : foo -> foo -> foo.
> Notation "A + B" := (fAdd A B) : foo_scope.
> Check (fA + fB) % foo_scope.
>>>> Error: Unknown scope delimiting key foo_scope.
Looking for “delimiting key” in the manual should help.
http://coq.inria.fr/distrib/current/refman/Reference-Manual014.html#hevea_command262
Vincent.
- [Coq-Club] Using Notation + Scope, t x, 09/21/2013
- Re: [Coq-Club] Using Notation + Scope, Vincent Laporte, 09/21/2013
- Re: [Coq-Club] Using Notation + Scope, t x, 09/21/2013
