coq-club - [Coq-Club] How do you use a gallina def in an Ltac fnc?
  • To: coqclub <coq-club AT inria.fr>
  • Subject: [Coq-Club] How do you use a gallina def in an Ltac fnc?
  • Date: Tue, 24 Sep 2013 11:10:41 -0400
I was working through CPDT, the Match chapter, and created an Ltac to pose a list of vals based off of the "Ltac length" function therein:
Ltac poseList ls :=
  match ls with
    | nil => idtac
    | ?i :: ?ls' => pose i ; poseList ls'
  end.
Goal True .
  poseList (1 :: 2 :: 3 :: nil) .
  Abort.
The above works as expected, adding n, n0 and n1 to the hyopthesis.
When I try to use:
Definition vals := (1 :: 2 :: 3 :: nil) .
Goal True .
  poseList vals .
  Abort.
I get an error:
  No matching clauses for match
Am I approaching this the wrong way, or am I missing some bit of syntax to make it work?
I also tried using:
Goal True.
  pose vals.
  match goal with
    | [ H : (_ : list nat) |- _ ] =>
      let v' := eval unfold H in H in
      poseList v'
  end .
to try to unwrap the vals, but it fails with a similar error.
  No matching clauses for match goal
Thanks,
Mike Kaplan
