- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] How do you use a gallina def in an Ltac fnc?
- Date: Tue, 24 Sep 2013 11:24:58 -0400
On 09/24/2013 11:10 AM, Mike Kaplan wrote:
Ltac poseList ls :=
match ls with
| nil => idtac
| ?i :: ?ls' => pose i ; poseList ls'
end.
When I try to use:
Definition vals := (1 :: 2 :: 3 :: nil) .
Goal True .
poseList vals .
Abort.
I get an error:
All this makes perfect sense, since Ltac matching is purely syntactic, and [vals] is neither [nil] nor a [cons]!
Many options are possible to do reduction in Ltac, and I do think CPDT introduces them at various points, but one option that would work here is replacing
match ls with
with
match eval hnf in ls with
- [Coq-Club] How do you use a gallina def in an Ltac fnc?, Mike Kaplan, 09/24/2013
- Re: [Coq-Club] How do you use a gallina def in an Ltac fnc?, Adam Chlipala, 09/24/2013
- Re: [Coq-Club] How do you use a gallina def in an Ltac fnc?, Mike Kaplan, 09/24/2013
