Re: [Coq-Club] Doubt about an error message in a definition using the refine tactic
- From: Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
- To: Rodrigo Ribeiro <rodrigogribeiro AT gmail.com>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Doubt about an error message in a definition using the refine tactic
- Date: Thu, 26 Sep 2013 16:12:17 +0200
Hi,
"intuition" does silly things with the "max_list" variable that ends to make
an unauthorized definition (for silly reason).
Add "clear max_list; " before "intuition" and things will go smoothly.
All the best,
Pierre B.
Le 26 sept. 2013 à 16:03, Rodrigo Ribeiro
a écrit :
> Hello to all!
> I'm having some trobules in understand an error message given by Coq in a
> rather simple definition using refine tactic. The complete code is:
> Require Import List Omega Arith_base.
> Definition max_list : forall (l : list nat), {n | forall n', In n' l -> n >
> n'}.
> refine (fix max_list (l : list nat) : {n | forall n', In n' l -> n > n'}
> match l with
> | nil => exist _ 0 _
> | x :: l' =>
> match max_list l' with
> exist x' _ =>
> match le_gt_dec x x' with
> | left _ => exist _ (S x') _
> | right _ => exist _ (S x) _
> end
> end
> end) ; simpl in * ; intuition ;
> try (match goal with
> | [H : context[In _ _ -> _],
> H1 : In _ _ |- _] => apply H in H1 ; try omega
> end).
> Defined.
> When I try to process the "Defined." command, Coq gives me the error:
> "Recursive definition of max_list is ill-formed.". Can someone explain to
> me why this is happening?
> Thanks!
> Rodrigo
- [Coq-Club] Doubt about an error message in a definition using the refine tactic, Rodrigo Ribeiro, 09/26/2013
- Re: [Coq-Club] Doubt about an error message in a definition using the refine tactic, Pierre Boutillier, 09/26/2013
- Re: [Coq-Club] Doubt about an error message in a definition using the refine tactic, Jason Gross, 09/26/2013
