Re: [Coq-Club] Doubt about an error message in a definition using the refine tactic
- To: Rodrigo Ribeiro <rodrigogribeiro AT gmail.com>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Doubt about an error message in a definition using the refine tactic
- Date: Thu, 26 Sep 2013 16:12:54 +0200
My guess, without trying anything, is that omega or intuition make use of [max_list] (and end up applying it to something other than l'). Try inserting a [clear max_list] between [refine] and [simpl in *]. Does that fix it?
-Jason
RodrigoThanks!When I try to process the "Defined." command, Coq gives me the error: "Recursive definition of max_list is ill-formed.". Can someone explain to me why this is happening?Hello to all!I'm having some trobules in understand an error message given by Coq in a rather simple definition using refine tactic. The complete code is:
Require Import List Omega Arith_base.
Definition max_list : forall (l : list nat), {n | forall n', In n' l -> n > n'}.
refine (fix max_list (l : list nat) : {n | forall n', In n' l -> n > n'} :=
match l with
| nil => exist _ 0 _
| x :: l' =>
match max_list l' with
exist x' _ =>
match le_gt_dec x x' with
| left _ => exist _ (S x') _
| right _ => exist _ (S x) _
end
end
end) ; simpl in * ; intuition ;
try (match goal with
| [H : context[In _ _ -> _],
H1 : In _ _ |- _] => apply H in H1 ; try omega
end).
Defined.
- [Coq-Club] Doubt about an error message in a definition using the refine tactic, Rodrigo Ribeiro, 09/26/2013
- Re: [Coq-Club] Doubt about an error message in a definition using the refine tactic, Pierre Boutillier, 09/26/2013
- Re: [Coq-Club] Doubt about an error message in a definition using the refine tactic, Jason Gross, 09/26/2013
