coq-club - Re: [Coq-Club] Program and simpl/compute
  • From: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
  • To: Fabien Renaud <Fabien.Renaud AT inria.fr>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Program and simpl/compute
  • Date: Wed, 2 Oct 2013 12:28:45 +0200
Hi,
Foo_func is the functional corresponding to Foo, when defining Foo by
well-founded recursion. Foo is then just the application of the wf recursion
principle to the functional and the proof of well-roundedness.
I'd recommend proving an unfolding lemma after you've defined [test].
It is provided by Function (test_eqn is the name I think), you can run
[Inspect 10] after defining test with Function to see what were the last
definitions.
Actually you'll also need to use measure induction again to prove your lemma.
Function provides a functional elimination principle for each function that
will use it internally. Just doing functional elimination will do both the
unfolding/case-analysis and provide you with the right induction hypotheses.
Hope this helps,
-- Matthieu
On 2 oct. 2013, at 11:39, Fabien Renaud
wrote:
> Hi,
> I have questions related to Program.
> I simplified my problem to the following:
> Require Coq.Program.Wf.
> Program Fixpoint test (l: list nat) {measure (length l)} :=
> match l with
> | nil => 0
> | X::R => (test (tl R))
> end.
> Obligation 1.
> induction R; simpl; omega.
> Defined.
> Ok my function is defined but now suppose I want to prove this:
> Lemma foo : forall l x, test (x::l) = 0.
> Proof.
> intros.
> Now simpl does nothing, and compute gives me something I don't want to read.
> Is there a way to do this kind of thing with Program? I tried with Function
> but simpl only expands to function_terminate and I'm stuck.
> By the way, when I defined a Program foo, sometimes I have "foo is
> defined", and sometimes "foo_func is defined". What does this mean?
> Thanks!
