coq-club - Re: [Coq-Club] Program and simpl/compute
  • From: Vincent Laporte <vincent.laporte AT gmail.com>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Program and simpl/compute
  • Date: Wed, 02 Oct 2013 15:48:10 +0200
Le 2013-10-02 11:39, Fabien Renaud a écrit :
> I tried with Function but simpl only expands to function_terminate
> and I'm stuck.
Hi,
If you use Function, then several objects will be defined: the function
itself and a couple of lemmas, one of them being test_equation.
Function test (l: list nat) {measure length} :=
match l with
| nil => 0
| X::R => (test (tl R))
end.
Proof.
induction R; intuition.
Defined.
Check test_equation.
(* test_equation
: forall l : list nat,
test l = match l with
| [] => 0
| _ :: R => test (tl R)
end
You can use this lemma to simplify some terms. For instance:
Goal ∀ x l, test (x::l) = 0.
intros x l. rewrite test_equation.
(* the goal is now: test (tl l) = 0. *)
Abort.
Moreover, there is an induction principle associated with your function
(its name is test_ind but that does not matter much). It might help
proving facts about the function, as in the following:
Lemma foo l : test l = 0.
Proof.
functional induction test l; auto.
Qed.
Regards,
Vincent.
