- To: "N. Raghavendra" <raghu AT hri.res.in>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Excluded middle and decidable equality
- Date: Wed, 2 Oct 2013 12:54:53 +0200
You might have used some axioms accidentally via tactics in, e.g., pigeonhole_principle_exmid_eq. Try [Print Assumptions pigeonhole_principle_exmid_eq.] (replacing pigeonhole_principle_exmid_eq with whatever theorem you want to check) to see if it depends on axioms. (I'm suggesting pigeonhole_principle_exmid_eq because I don't see how that is possible without classical axioms.)
-Jason
At 2013-10-02T02:02:12-07:00, Daniel Schepler wrote:
> On Wednesday, October 02, 2013 11:05:44 AM N. Raghavendra wrote:
>> Definition pigeonhole_principle (X : Type) : Prop :=
>> forall l1 l2 : list X,
>> (forall x : X, appears_in x l1 -> appears_in x l2) ->
>> length l2 < length l1 ->
>> repeats l1.
>> Theorem exmid_appears_in_pigeonhole_principle :
>> forall X : Type,
>> exmid_appears_in X -> pigeonhole_principle X.
> For what it's worth, here's a proof of pigeonhole_principle without any
> excluded middle assumptions.
I am a bit confused now, because I've proved in Coq, without invoking
any libraries other than Init, that
exmid_eq X -> exmid_appears_in X -> pigeonhole_principle X ->
exmid_eq X
for every type X, where (exmid_eq X) is the proposition that equality in
X is decidable, and (exmid_appears_in X) is the prop that list
membership in X is decidable. So, if one can prove the pigeonhole
principle without any classical logic assumptions, it follows that
equality is decidable for all types, without any classical logic
assumptions. Does that sound right?
Best regards,
Raghu.
N. Raghavendra <raghu AT hri.res.in>, http://www.retrotexts.net/
Harish-Chandra Research Institute, http://www.hri.res.in/
- Re: [Coq-Club] Excluded middle and decidable equality, N. Raghavendra, 10/02/2013
- Re: [Coq-Club] Excluded middle and decidable equality, Daniel Schepler, 10/02/2013
- Re: [Coq-Club] Excluded middle and decidable equality, Jason Gross, 10/02/2013
- Re: [Coq-Club] Excluded middle and decidable equality, Alan Schmitt, 10/02/2013
- Re: [Coq-Club] Excluded middle and decidable equality, Cedric Auger, 10/02/2013
- Re: [Coq-Club] Excluded middle and decidable equality, N. Raghavendra, 10/04/2013
