- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Excluded middle and decidable equality
- Date: Wed, 02 Oct 2013 16:58:06 +0530
- Cancel-lock: sha1:PzlzShVrDY8T2CDS3guNJ2NYILI=
At 2013-10-02T12:54:53+02:00, Jason Gross wrote:
> You might have used some axioms accidentally via tactics in,
> e.g., pigeonhole_principle_exmid_eq. Try [Print
> Assumptions pigeonhole_principle_exmid_eq.]
> (replacing pigeonhole_principle_exmid_eq with whatever theorem you
> want to check) to see if it depends on axioms. (I'm
> suggesting pigeonhole_principle_exmid_eq because I don't see how that
> is possible without classical axioms.)
Thanks for pointing it out.
Print Assumptions pigeonhole_principle_exmid_eq.
Axioms:
appears_in_dec : forall (X : Type) (x : X) (l : list X),
{appears_in x l} + {~ appears_in x l}
I had introduced a
Parameter appears_in_dec :
forall {X : Type} (x : X) (l : list X),
{appears_in x l} + {~ appears_in x l}.
to define a function used in the proof of pigeonhole_principle_exmid_eq.
I was going around in circles!
Best regards,
Raghu.
N. Raghavendra
<raghu AT hri.res.in>,
http://www.retrotexts.net/
Harish-Chandra Research Institute, http://www.hri.res.in/
- Re: [Coq-Club] Excluded middle and decidable equality, N. Raghavendra, 10/02/2013
- Re: [Coq-Club] Excluded middle and decidable equality, Daniel Schepler, 10/02/2013
- Re: [Coq-Club] Excluded middle and decidable equality, Jason Gross, 10/02/2013
- Re: [Coq-Club] Excluded middle and decidable equality, Alan Schmitt, 10/02/2013
- Re: [Coq-Club] Excluded middle and decidable equality, Cedric Auger, 10/02/2013
- Re: [Coq-Club] Excluded middle and decidable equality, N. Raghavendra, 10/04/2013
