Re: [Coq-Club] Fixpoint termination issue; why doesn't this simple example go through?
- From: Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
- To: Michiel Helvensteijn <mhelvens AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Fixpoint termination issue; why doesn't this simple example go through?
- Date: Sat, 5 Oct 2013 16:45:35 +0200
>> (1) Is there a theoretical reason it shouldn't?
No
>> Something I'm just not seeing?
Well yes, but it is normal that you don't see it :-)
All arguments of constructors are NOT admissible subterms, polymorphic
arguments of a constructors must not be !
See the example
Inductive I : Type := C: (forall (P : Type), P->P) -> I.
Definition Paradox : False :=
(fix ni (i :I):False := match i with | C f => ni (f i) end)
(C (fun (P :Type) (x :P) => x)).
to understand why !
Coq registers "admissible for recursive calls" arguments of a constructor at
definition time. Consequently, as the first argument of cons in
Inductive list (A : Type) : Type := nil : list A | cons : A -> list A -> list
A.
has an unknown type "A". it will never be OK to use it (or one of its
subterm) as a subterm of the recursive argument ! (Yes, Coq should make the
check at usage time. Everything would be fine and your trouble as the one of
every Coq user before you would be solved)
There is sometime a work-around. In "match x with | cons a _ => ... | _ =>
... end", if 'x' is the recursive argument, we have just seen why sadly 'a'
will never be recognize as a subterm but if 'x' is a subterm already then 'a'
will be one.
As a consequence, inner fixpoints (has the fold hidden in Robbert solution)
sometime saves you … (the argument of inner is a subterm)
Pierre B.
Le 5 oct. 2013 à 15:57, Robbert Krebbers
<mailinglists AT robbertkrebbers.nl>
a écrit :
> On 10/05/2013 03:51 PM, Michiel Helvensteijn wrote:
>> (2) What is the recommended way of solving this? In my search I've
>> found some descriptions that might be related, but I'd really
>> appreciate a simple example.
> The following alternative definition does through:
> Fixpoint my_sum' (l: NatTree) : nat :=
> match l with
> | leaf n => n
> | inner l => fold_right plus 0 (map my_sum' l)
> end.
> Definition my_sum (l : list NatTree) : nat :=
> fold_right plus 0 (map my_sum' l).
- [Coq-Club] Fixpoint termination issue; why doesn't this simple example go through?, Michiel Helvensteijn, 10/05/2013
- Re: [Coq-Club] Fixpoint termination issue; why doesn't this simple example go through?, Robbert Krebbers, 10/05/2013
- Re: [Coq-Club] Fixpoint termination issue; why doesn't this simple example go through?, Pierre Boutillier, 10/05/2013
- Re: [Coq-Club] Fixpoint termination issue; why doesn't this simple example go through?, Frédéric Blanqui, 10/07/2013
- Re: [Coq-Club] Fixpoint termination issue; why doesn't this simple example go through?, Pierre Boutillier, 10/07/2013
- Re: [Coq-Club] Fixpoint termination issue; why doesn't this simple example go through?, Frédéric Blanqui, 10/08/2013
